Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
todde
Post
by todde » Thu Jun 18, 2015 12:04 pm
Okay thanks for the tip. Now I noticed another issue while recording: the volume level is higher for about the first 15 seconds of the record and then it goes down to what I would consider "normal" level. The difference between that first 15 seconds and the rest are quite noticeable though, as the sound escalates and then "falls off a cliff". I've tried to just start the recording 15 seconds later, but it still does the same thing. I will try another record, but I don't think that's the problem. Never had this issue before. Any suggestions? Thanks.
- Quality Assurance
Post
by Gale Andrews » Thu Jun 18, 2015 12:47 pm
todde wrote:Now I noticed another issue while recording: the volume level is higher for about the first 15 seconds of the record and then it goes down to what I would consider "normal" level. The difference between that first 15 seconds and the rest are quite noticeable though, as the sound escalates and then "falls off a cliff". I've tried to just start the recording 15 seconds later, but it still does the same thing. I will try another record, but I don't think that's the problem. Never had this issue before. Any suggestions?
It is probably an
enhancement for microphone recording that is meant to help when recording conversations, or it's a sound effect you have turned on in the sound card. Try turning the mic enhancements off. Also turn Skype off if you have it.
The suggestion is the same as we've made throughout this topic.
Do not record LP's into the microphone port because the microphone port is not meant for that.
Post
by kozikowski » Thu Jun 18, 2015 7:17 pm
that was Capitol
It was capitol wasn't it? Oh, you mean the company.
todde
Post
by todde » Sat Jun 20, 2015 3:39 pm
Gale Andrews wrote:todde wrote:Now I noticed another issue while recording: the volume level is higher for about the first 15 seconds of the record and then it goes down to what I would consider "normal" level. The difference between that first 15 seconds and the rest are quite noticeable though, as the sound escalates and then "falls off a cliff". I've tried to just start the recording 15 seconds later, but it still does the same thing. I will try another record, but I don't think that's the problem. Never had this issue before. Any suggestions?
It is probably an
Okay thanks! I had the "Enable audio enhancements" box checked under microphone properties. So I unchecked it and it seems to have resolved my issue.
todde
Post
by todde » Sat Jun 20, 2015 3:45 pm
I accidentally pressed something and changed my screen. Any idea why my recording is clipped at 0.5 and -0.05? Thanks.
- Untitled.jpg (353.81 KiB) Viewed 237 times
- Quality Assurance
Post
by Gale Andrews » Sat Jun 20, 2015 4:22 pm
todde wrote:I accidentally pressed something and changed my screen. Any idea why my recording is clipped at 0.5 and -0.05?
Did you run an effect like Amplify or Normalize? You can Edit > Undo that.
Is that a recording you just made? If so did you reduce the input volume slider? If it is a microphone recording it does seem to be stereo, but some microphone ports can detect line-level stereo. They will still not give you as good quality as the stereo line-in on a USB interface would.
todde
Post
by todde » Sun Jun 21, 2015 12:01 pm
Okay I think I got it figured out. Thanks for the help. Great forum: got my questions answered quickly and helped a lot!
