I think I got that one. That's using Analyze > Contrast in its purist form all the way through to the end. I've never done that. I just use the first number. It turns out the top portion of the tool works about the same way that ACX does (attached). But that's as far as I go. The RMS (loudness) value of my clip or show is -20.0dB. Close.Regarding the WCAG 'test,' that's a result on the Analyze/Contrast screen, which collects sound data and then gives some numbers about background noise compared to foreground, so one might think it's a sound test.
ACX doesn't use the relative values, so the rest of the tool isn't valuable.
And since ACX Check became available, you don't even need to do that. ACX check does the leg work of finding all the values exhibited by your clip and tells you what they are, and then compares them to the ACX standard and tells you whether you passed or failed.
Handy thing, that.
Let me see about that download. This would be so much handier with a forum elf who speaks Windows.
