1.3.6 Bug with Invert, Mix and Render Tracks
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
khead
Post by khead » Tue Feb 03, 2009 11:17 pm
This is the main use I've had for Audacity over the years, to examine differences between files.
Just tried with the latest version, and importing the exact same file twice will produce noise when you invert one and mix and render with the other.
khead
Re: 1.3.6 Bug with Invert, Mix and Render Tracks
Post by khead » Wed Feb 04, 2009 5:32 am
OK - Problem come from using Apple Lossless files. Wav works fine.
bsdwarez
Post by bsdwarez » Sun Apr 12, 2009 2:17 am
khead, thanks for reply. I have some problems with Apple Lossless files too.
jan.kolar
Post by jan.kolar » Sat May 02, 2009 9:38 am
Audacity includes artificial noise at some occasions. This is callend DITHERing and its purpose is to reduce distortion caused by mathematical rounding.
You can
- ensure your Audacity track bit depth (Sample Format) is at least as in your input files.
(do not have 16bit tracks in Audacity)
- switch off dithering in Preferences
I guess your Apple Lossless file differes from your wav file by having higher bit depth (e.g. 32 versus 16 bit)
