De-Clicker Settings Problems
ChristineG
Post by ChristineG » Thu Jun 04, 2015 8:26 pm
Hi.
FirstIy I apologise for the essay length post for my first forum post.
My setup is a 2.1Ghz Dual Core Athlon Laptop with Windows Vista SP2
Audacity 2.1 (The latest build other than the nightly builds)
Additional ny plugins: De-Clicker ,De-Esser, EZ-Patch, PopMute, and NoiseGate,
Additional VST files:Floorfish Expander/NoiseGate, and finally Cockos ReaFIR and Cockos ReaEQ.
I also use a Brazilian program called OCENAUDIO for the DC Offset, the amplitude, high and low pass filters, and the bandpass or notch filter, and do the editing. in Audacity 2.1
I am having problems taking crackle and pop out of a couple of tracks from a 1985 vinyl LP. Click Removal does not get anywhere with it on the various settings. I have only four month experience on vinyl to PC restoration since February in fact so I am still a newby. I am following the Audacity LP Workflow in tandem with the above mentioned extras for cleaning things up:
I have followed the 9 pages of info on the forum related to the excellent De-Clicker by PaulL, from this link http://forum.audacityteam.org/viewtopic ... 42&t=79278 , but struggling with two tracks. I have tried default settings and it turns the spikes to mud where the spikes used to be. I then took a Spectogram Log F reading, and left the bands in De-Clicker where they were on 12 but chose between 250hz to 18000 hz. I raised the bottom end hz as suggested by PaulL. At these settings I get oscillation. If i raise the bottom end again I get mud or whistles. Increasing the bands didn't work. ReaFir does clear everything up but only at the expence of the actual audio. I also trialled ClickRepair, and got similar results to ReaFir, ClickRepair has since run out of trial days. Any help would be appreciated. Sorry for the over detailed info. I have finished four tracks successfully on the same album, but not these two. Here is a sample of one of them. Thanks in advance.
Christine. :( PS I learned my way around the bands from this page. http://bobbyowsinski.blogspot.co.uk/201 ... bands.html
test.wav
Sterio Wav file have left the front noise in as there would be no noise profile for noise reduction or click removal
(1.87 MiB) Downloaded 35 times
Re: De-Clicker Settings Problems
Post by kozikowski » Thu Jun 04, 2015 8:31 pm
Audacity 2.1
Just to be obsessive, we don't make an Audacity 2.1 or 2.10. Those are bogus versions. The current version is Audacity 2.1.0.
http://web.audacityteam.org/download/
ChristineG
Post by ChristineG » Thu Jun 04, 2015 8:42 pm
Thanks Koz. I am using 2.1.0. I was being lazy and didn't put the additional 0. Apologies. :(
Trebor
Post by Trebor » Fri Jun 05, 2015 7:38 pm
ChristineG wrote:... also trialled ClickRepair, and got similar results to ReaFir, ClickRepair has since run out of trial days ...
Brian Davies ClickRepair was designed for this purpose : de-crackling records ...
ChristineG
Post by ChristineG » Sat Jun 06, 2015 3:27 pm
Thanks Trebor for the excellent befor and after flac file. I couldn't get my settings as good as that when I trialled ClickRepair before my trial time ran out. It is certainly a purchase for the future. Embarrassingly I have solved this problem within 24 hours of posting, and thought I would share this everybody still using the De-Clicker by PaulL. I was getting desparate and took a complete track FFT (Fast-Fourier Transform) reading from Ocenaudio . Then back In Audacity I set the bottom end Hz range to 100 in De-Clicker, and the top end to 22000hz, and left the Bands on 12 default. This has worked for three tracks in a row, but i am not techy enough to know why. It takes about 9 minutes for a 3.5 minute track. Here is a screen shot of the settings. Thanks again for your help.
I have enclosed the settings in the file below.
De-Clicker Settings.JPG (54.86 KiB) Viewed 905 times
Trebor
Post by Trebor » Sun Jun 07, 2015 7:24 pm
ChristineG wrote:Thanks Trebor for the excellent befor and after flac file. I couldn't get my settings as good as that when I trialled ClickRepair before my trial time ran out ...
The Brian Davies ClickRepair settings I used were 75 on both click & crackle, ( may not be optimal )
ChristineG
Post by ChristineG » Wed Jun 10, 2015 4:15 pm
Thanks for the reply Trebor. Sorry I have been a bit of time get back to you, but I was trying one or two things out. I tried your idea of setting to 75 but it made no difference. My settings as on the above screen were the best to date. I thought everything was ok, but when I play either of my two tracks with the settings above on a better quality sound player like KMPLayer through the laptop, or wire my laptop to my hifi via the Aux I get a very slight oscillation on both tracks. Leveler does not fix this so my maths via the FFT is floored :( . Thanks again for your help.
Trebor
Post by Trebor » Thu Jun 11, 2015 2:13 pm
ChristineG wrote:Thanks for the reply Trebor. Sorry I have been a bit of time get back to you, but I was trying one or two things out. I tried your idea of setting to 75 but it made no difference. My settings as on the above screen were the best to date.
the 75&75 settings were what I used on Brian Davies ClickRepair , not Audacity.
ChristineG
Post by ChristineG » Thu Jun 11, 2015 4:19 pm
Thanks Trebor. I realise that, I was just trying as a frequency change idea, setting the bottom end of the frequency bands to 75 in Audacity because PaulL said in the original thread that there was no improvement by moving the threshold figure, although I did try that with threshold readings from OCENAUDIO. I have found out something interesting which does go against the original notes however. PaulL mentioned something about increasing the bottom end of band frequency or increasing the band number. If I move the bottom end of the band frequency up from 150 anywhere between there and 300 I get more mud. Increasing the number of bands hasn't helped. My best result to date was with REAFIR VST Plugin which takes all the clicks away, but takes all of the clarity out of the music. I then raise the whole wave, and put clarity back into it with REAEQ, but doing that brings some of the pops back. I also have to watch out for clipping. It looks like I am purchasing ClickRepair. :) Thanks for you help and quick replys.
Trebor
Post by Trebor » Thu Jun 11, 2015 8:15 pm
ChristineG wrote:... It looks like I am purchasing ClickRepair
ClickRepair looks like the best value for money if you are digitizing vinyl , other options can cost an arm & a leg.
