Audacity won't open on MacbookPro [SOLVED]
Help for Audacity on macOS.
macman
Post by macman » Sun May 31, 2015 5:38 am
I've used Audacity for years. Including just a week or so ago. Tonight I opened it to import and edit a new piece of music. It seemed to open but the "How to get Help" window that always opens with the OK box was frozen. I could not close it - it just beeped every time i clicked. it. Likewise all of the Audacity drop down menus were greyed out - nothing was active, not even Quit. I had to Force Quit and start over. I did this multiple times with the same result. I also tried restarting the compuer and shutting down completely and rebooting - same result. At that point I figured there might be a newer version and indeed there is. So I downloaded it, installed by dragging the folder into Applications. I DID NOT run it from the DMG and I left the app in its folder. Again same results. I've downloaded the app twice now and still the same results.
I do not understand what is happened. I've changed nothing on my computer, added no new software, etc. All of a sudden it simply woould not open and neither will the newly installed version. I'm on a MacBookPro retina with OSX 10.9.5.
Any ideas???
Re: Audacity won't open on MacbookPro
Post by Gale Andrews » Sun May 31, 2015 10:48 am
If you have tried to retinize Audacity this can cause problems.
Make sure you got Audacity 2.1.0 from this address: http://web.audacityteam.org/download/mac.
Then, see http://manual.audacityteam.org/o/man/fa ... tml#launch. If you've not installed new plugins or connected new audio devices, follow the steps in that link to reset Audacity Preferences. That is, force quit Audacity, open Finder, Go > Go to Folder and type:
Code: Select all
~/Library/Application Support/audacity/
Then delete the audacity.cfg file in that folder.
macman
Post by macman » Sun May 31, 2015 5:46 pm
OK - I trashed the audacity folder and the downloads - cause got it somewhere else apparently. I downloaded form the link you provided. Opened Audacity and the same issue - it froze before I could even click the OK on How to Get Help screen. I closed it and then followed the link you provided - used finder to go to "library/audacity support/audacity so I could delete the audacity.cfg folder and thus reset preferences, but finder says "The folder can't be found." How can that be following a complete fresh install??
Indeed I manually went to Library/App support/ and there is no audacity folder?
billw58
Post by billw58 » Mon Jun 01, 2015 1:31 am
You missed the "~/" in front of "Library" in the path to the folder.
- Bill
macman
Re: Audacity won't open on MacbookPro [SOLVED]
Post by macman » Mon Jun 01, 2015 10:30 pm
Doh! My bad. That fixed it - thanks!!
