All tracks timeshift together in KDE Mint [SOLVED]
Please state:
Veerstryngh Thynner
Post by Veerstryngh Thynner » Sat May 30, 2015 7:17 am
Hello all,
May I please enlist your help for bypassing strange limitations encountered in Audacity?
Currently on my laptop is Audacity 2.05, in KDE Mint. But since my laptop doesn't have mic/line In, I usually start work on my desktop version (Audacity 2.03, in Ubuntu 12.04 LTS). Scores (or parts of scores) then go back and forth between desktop and laptop. Furthermore, Ubuntu 12.04, on my desktop, is actually on its last legs. And I still don't know as to whether this may be a contributing factor for difficulties presently experienced in Audacity 2.05 in Mint.
Most bedeviling are the following two phenomena:
- Anything from a thumbnail or external hard disk pasted into a new track will move the previous track(s) to a totally random place (usually somewhere after the new one) - on which I'll have no influence whatsoever, of course;
- Time-shifting separate tracks is now impossible: if a score consists of, say, four tracks, all four will move in a body.
This is all very impractical, of course. But nothing in Edit>Preferences seems to be out of kilter, on the face of it. So now I really don't a clue as to how to sort out this peculiar glitch. Any ideas or suggestions?
Thanks very much.
tnob
Reason: changed title to be more descriptive
Re: Audacity behaving strangely in KDE Mint
Post by steve » Sat May 30, 2015 9:27 am
tnob wrote: Time-shifting separate tracks is now impossible: if a score consists of, say, four tracks, all four will move in a body.
I think that is the clue. Check that you have not accidentally enabled "Sync Lock" (see: http://manual.audacityteam.org/o/man/ed ... .html#link)
Veerstryngh Thynner
Re: All tracks timeshift together in KDE Mint [SOLVED]
Post by Veerstryngh Thynner » Sun May 31, 2015 7:50 am
Thanks very much Steve!
Sync Lock was indeed 'on'. After switching that off, everything returned to normal. Big relief!
tnob
