My audio sample
Jan B.
Re: My audio sample
Post by Jan B. » Fri May 29, 2015 10:25 am
Hi, Koz, I don't understand it at 5 in the morning, but when I can I will go through the directions and try to do it.
But in the meantime, since my mic isn't omnidirectional, should I take it out of that box? It makes it hard to get the script in front of my eyes. Or does the box help?
Thank you so much! I may have to ask more about the steps, too, if I can't actually handle it! But I will try.
Jan B.
Re: My audio sample
Post by Jan B. » Fri May 29, 2015 8:51 pm
Hello,
I think my question about 'inside the sound box' vs 'outside the sound box' got buried in my gratitude. I was wondering which set up was 'better' in terms of fewer problems to fix at the end, in spite of the fact that my mic isn't omni-directional at all and so probably doesn't need the sound box (I think the internet directions I used were for an omnidirectional Samson). There's a dif in the sound of these two selections, but I can't tell which one is 'better' in the terms mentioned, that is, more amenable to the corrections Koz gave me. Outside the box the mic is more sensitive and there was clipping but I didn't get that in the section I copied and saved.
Thank you!
Janet
Samson Inside Sound Box.wav
(718.04 KiB) Downloaded 15 times
Samson Outside sound box.wav
(724.04 KiB) Downloaded 12 times
Re: My audio sample
Post by kozikowski » Sat May 30, 2015 12:45 am
I know it's probably inconvenient, but you still need the box. The microphone receives from the sides, too, just not quite as well and I expect your room echoes to go way up if you stop using it.
I can't listen to the clips right now. A bit later.
Yes, I'm not surprised that the volume went up when you took the box away. That's not clear, quality voice. That's all the extra echoes.
If you have trouble following the corrections, just say so. Give me an idea where you got stuck.
Jan B.
Re: My audio sample
Post by Jan B. » Sat May 30, 2015 8:24 pm
Enclosed, please find LF_rolloff_for_speech.xml.zip. Unzip it and that should leave you with LF_rolloff_for_speech.xml. That's a custom effect designed by Steve to work with Effect > Equalization. Remember where you put it.
Adding Eq Curves
- Open the show or Generate > Noise > OK. It's just to get something on the timeline.
- Effect > Equalization > Save/Manage Curves > Import.
- Point at LF_rolloff_for_speech.xml > OK. (it won't open the ZIP. You have to decompress it)
- From that point forward it appears as a standard curve.
Now on to your show.
— Open the show, chapter, clip, whatever. Select the whole thing by clicking just above MUTE.
Effect > Equalization > Select Curve: LF rolloff for speech, Length slider all the way up (8191) > OK.
Drag-select a second or so of pure room noise, no voice. In that test clip, I got it from 1.8 to 2.2 seconds. If your room noise never changes, you may be able to get the profile from that test clip but use it on your show. If you change anything like move the microphone, you'll have to get the profile from the actual show. Anyway.
Effect > Noise Reduction: Profile.
Select the whole show by clicking just above MUTE.
Effect > Noise Reduction: 12, 6, 6 > OK
Effect > Normalize: [X]Remove DC, [X]Normalize to -3.2 > OK
That's it. If you do that to each chapter, export as WAV (safety) and then re-export as MP3, you should be good to go.
Hi, Koz,
Those are the directions you gave me, I pasted them above. Question #1: Are there actually two sets of directions here, one that begins with the word 'Enclosed' and the second that begins with the phrase, 'Now, on to your show.' I did what the first section says, I downloaded it and unzipped it and put it in my doc folder for Audacity stuff. But the rest of that section lost me. I don't know what you mean by 'point at.' Also, I don't know what 'it' is as in 'from this point forward, it appears as a normal curve.' What does?
Second question: Then in the second section, I selected the First Chapter, just completed, and tried to do the rest of the steps but only got to Effect/Equalization, because I don't have any words on the screen like Select Curve LF Rolloff for Speech. And there's only a straight green line dead center of the dialogue box that opened with Effect/Equalization, no curves.
The rest of the steps, I think I see those elements and will be able to do it, but I'm stuck at the beginning part.
Thank you, if I made enough sense to help me,
Janet
Jan B.
Re: My audio sample
Post by Jan B. » Sun May 31, 2015 1:22 am
Koz, may I please ask a separate question? If I want to be able to present a download containing multiple chapters of a novel which will play in succession, how exactly do I do that? I am presently editing the first chapter of the novel (the noise reduction you gave me made visible tidying and I was just going along taking out too long pauses) and was thinking of how I would soon begin the second, and it dawned on me I don't know how it works. Shall I save Chapter Two as a separate file? And in the end, will they all go in one folder, and that folder shall--unfold!--for the listener? : D I know nothing! I should be asking this of a producer of a website that would do this, but no, I just set up a wordpress site and expect to do it myself, using some kind of app, and Paypal. Someone mentioned Spotify.
Do you happen to know how it works?
Thank you, Janet
Re: My audio sample
Post by kozikowski » Mon Jun 01, 2015 4:39 am
OK. The top half of that instruction list is to make a special sound filter available in the second half. It's a special custom voice filter that's not included with normal Audacity. That's why you couldn't find LF_rolloff. Unless you installed it, it's just not there.
I need to push details off until tomorrow. Sunday night and Monday mornings can be a little challenging.
And what are you going to do after lunch. :D
Re: My audio sample
Post by kozikowski » Mon Jun 01, 2015 8:18 pm
Where did you get stuck with this? Did you have any trouble "unzipping" LF_rolloff_for_speech.xml? It may not say ".xml" on the end. This is Windows trying to "help you" by hiding part of the filename.
You can force Windows to show you the whole, complete filename. Sometimes that's a good idea.
Hidden File Extensions - Windows
-- Start > My Computer > Tools > Folder Options > View > [ ] Hide Extensions for Known File Types (deselect)
-- Apply (to this folder) or Apply to All Folders
-- OK
Let us know.
Jan B.
Re: My audio sample
Post by Jan B. » Tue Jun 02, 2015 2:20 pm
Hi, Koz!! Boy, you made me laugh. I have overcome tougher obstacles than Paypal and Spotify. For example, I--me, not a company--brought my entire household of goods across the border from Mexico to the US at Nuevo Laredo. I will not elucidate. : D
Here's where I got stuck with the --the roll-out thing (can't go get the name of it, am in a new window!). I did the steps but now don't know what to do with it. I see it gives settings. I think I downloaded it and unzipped it ok (the unzipped file has the name you gave me to recognize if I'd unzipped it right), and I can open it and read those settings.
But for the other section, I have applied the steps, normalize and equalization--I'm going from memory here due to lazy unwillingness to close this window and go look!--to my whole first chapter and judging from the change in the silence parts (from squiggly to darn near straight) I think a lot of noise got eliminated. Am grateful as all!
But what about the roll out thingy?
Janet
Re: My audio sample
Post by kozikowski » Wed Jun 03, 2015 11:45 pm
"Rolloff" and many of its cousins like "notch," "clipping," shelving filter," "brick wall" and "tilt" are all visual words describing something aural.
Clipping is the easy one. That's when the real life sound becomes so loud that the recording system can't handle it. The sound keeps getting louder but the recording doesn't. If you look closely at the blue waves on the timeline, the tip of each wave is damaged and it looks like someone came by with scissors and clipped them off. Clipping is important because you can't fix that later and it can permanently damage your show.
In the specific case of rolloff, many sound systems make sounds and tones that are very low pitch (thunder, church organ, earthquake) either accidentally or as an actual part of the show. Unless you are shooting an orchestra, most of these sounds aren't helpful. Not only that, they take up room in your show and can mis-direct tools and filters, and a lot of the time, you can't even hear them.
"For Some Reason" Audacity thinks my show is a lot louder than I can hear.
There's a Hollywood joke about filming earthquakes. You can't. You can't hear them, either, so the best you can do is the vibrating whine glass. "Oh, my goodness, is that an earthquake?" switch to a closeup of the wine glass.
To avoid that problem, Steve wrote the equalization plugin: LF_rolloff_for_speech. When plugged into Effect > Equalization, it removes all those low-pitched tones and for most vocal performers, doesn't affect the voice.
Noise Reduction, for one example, has a lot less work to do with those tones gone and you're likely to get a cleaner and clearer show.
When you unzip the tool, do you see LF_rolloff_for_speech, or LF_rolloff_for_speech.xml?
Oh, "rolloff?" When Effect > Equalization is used with Steve's plugin (and the "length" slider all the way up) the pattern on the screen is like a roller coaster and you are about to roll off the top. Steve specifically designed this tool to do little or no damage to the sound that is left. There are sharp cut-off or cliff filters that aren't graceful at all and they can create sound damage.
Screen Shot 2015-06-03 at 16.37.36.png (28.98 KiB) Viewed 463 times
Jan B.
Re: My audio sample
Post by Jan B. » Thu Jun 04, 2015 2:58 pm
Hi, Koz,
You did so much work on your reply, but it isn't what I need! I can't get it to work. I downloaded and unzipped the file, I stored it in my documents in my Audacity folder, and the name appears thus: LF_rolloff_for_speech, XML document. That's the name I believe you gave me to prove I had unzipped it okay. I can open this files and it gives a list of settings. There's no indication to me that such a small document would need to be zipped at all so perhaps I don't even have the right file--maybe this is the documentation, not the program.
Anyway, here's the place in your directions that things don't work, because the choice Curve: LF rolloff for speech does not appear anywhere on the screen. I can't make the selection:
Can you help me with this part? Thank you!
Janet
