Help request! Making a 'hiss' echo
nedius
Post by nedius » Wed May 06, 2015 5:04 pm
Hi there,
I'm trying to make a 'radio transmission' style voice effect that matches that used in the X Wing and TIE Fighter series computer games.
The effect I need I'll add an example of in a bit, but it sounds like a radio transmission.
I can get the voice sounding like it is coming over a radio using the equaliser and high pass filters, but what I can't get is the static hiss that accompanies it.
I can add white noise in the back ground, but in the game, the noise isn't constant - it is like an echo. It's as if someone has put a .1 second delayed echo, then convereted the echo into a static hiss rather than a voice.
Any way of doing this in Audacity? Will try to get an example.
Thanks!!
Re: Help request! Making a 'hiss' echo
Post by kozikowski » Wed May 06, 2015 6:47 pm
Either post a link to the effect, or a sample sound file of the actual effect.
http://forum.audacityteam.org/viewtopic ... 49&t=72887
nedius
Post by nedius » Wed May 06, 2015 7:18 pm
Here it is:
1m1r2.wav
TIE Fighter radio message
(56.92 KiB) Downloaded 23 times
Post by kozikowski » Wed May 06, 2015 7:29 pm
There's not of actual noise there, so it could be almost anything. How about "Dirty Noise" (attached). Does that work?
DirtyNoise.wav
(62.39 KiB) Downloaded 17 times
Trebor
Post by Trebor » Wed May 06, 2015 11:34 pm
nedius wrote:... but what I can't get is the static hiss that accompanies it.
It sounds like quantization noise ...
Dubya, before-after , EQ then Steve's Quantization distortion @85.wav
the setting of 85 on quantization distortion maybe a bit too much.
(1.1 MiB) Downloaded 23 times
Steve made a distortion plugin for Audacity which includes a "quantization" option,
that plugin can be downloaded from here ... http://forum.audacityteam.org/viewtopic ... 96#p237796
nedius
Post by nedius » Thu May 07, 2015 7:27 pm
that sounds spot on! thanks!!
Trebor
Post by Trebor » Thu May 07, 2015 8:42 pm
Using a noise-gate with a 100-200ms decay will emulate the squelching effect of an actual radio transmission : where the hiss persists for a fraction of a second after the person stops speaking, then there is true silence until they speak again.
