it all seems a bit confusing to me and it tells me that I cannot rely that everything always can be expected to work reliably.
Anyway, I recognize that I should point out once more that our interface is different from what you know from other devices and what you obviously assume is the same here:
Our Interface supports only one sample rate. This sample rate is the sample rate of the incoming S/PDIF digital audio data stream, which cannot be influenced by the PC or the interface. In order to handle different incoming sample rates, the interface measures the sample rate and offers it to the system as the only available sample rate. When the sample of the external digital audio data stream is changed and the interface notices that, it disconnects from the USB and reconnects as a different device with the actual sample rate. The sample rate is part of the device's name, as you can see on the screen shot.
This should also answer your first reply. Sorry when I made it not more clear.Yes, in the event of problems you should select the device in Audio MIDI setup, as I suggested in my first reply.
There is nothing that can be set in Audio MIDI Setup for our device. There is only one sample rate, always 24 bit and no volume or other control available. That' exactly how we want it.It may well be instructive to see what Audio MIDI Setup reports as your device's sample rate choice(s)
What does "open a DAW" mean? A different digital audio workstation software? I tested the recording functions with Audacity and a few other programs (Cubase, TwistedWave, WavePad). All of them worked from the beginning on, only Audacity needed a couple of days to understand what expect from it
Uwe
(once again thanking you for your tips ans answers)
