Error could not save project....file isnot writable disk ful
couchgolfer
Keep getting error message that could not save project.....file is unwritable or disk is full
disk is not full, no symbols in name just numbers letters and spaces. have 2.1.0 downloaded and still error message.
does anyone know how to fix this and if so please explain in detail as not that techy....thanks
Re: Error could not save project....file isnot writable disk
That's not the only thing which can cause that. Are you using network connected drives? Did you use comments in the metadata and did you put punctuation marks there? Are you running Audacity over a network?
Will the project save to your desktop, just as a test?
couchgolfer
no network, plugged directly into tower...don't know how to save to desktop. can't save at all keep getting the error message. have set to use different folder and have no idea how to mess with metadata so no idea on that either. thanks for any help you can give
- Quality Assurance
Click "Save in:" at the top of the Save Project window and click "Desktop".
If you can't save there then you have permissions or write problems on your computer, or you are experiencing a rare issue where Audacity won't write files in XML format (the project's AUP file is a type of XML file).
If you are still stuck, try File > Export Audio... and export as WAV.
couchgolfer
finally worked saving in desktop. had tried exporting to wav but as it would not save could not export. desktop worked great. thanks for the assist it is much appreciated.
- Quality Assurance
If you were trying to save or export to Program Files, you can't unless you are logged in as an administrator.
couchgolfer
Just recorded a new project and attempting to save to desktop and that crazy not enough disk space or unwritable error came back.....now what? nee4 assistance again with step by step instructions also tried saving to backup drive that had same error
thanks
Vicki
thanks
Vicki
- Quality Assurance
When exporting and when saving an Audacity project, Audacity may warn you (or not respond correctly) if you type a file name that includes characters that are forbidden by the operating system.couchgolfer wrote:Just recorded a new project and attempting to save to desktop and that crazy not enough disk space or unwritable error came back.....now what? nee4 assistance again with step by step instructions also tried saving to backup drive that had same error
Do not use any of these Forbidden Characters on Windows in your file name:
Code: Select all
\ / : * ? " < > |If that did not help, try rebooting the computer.
Is there a chance that Audacity will, at some point, allow these 'forbidden characters' in file names?
Bob H
Bob H
It's not up to Audacity. Macs allow some of those characters now.
