1.3.7 crashes on load
brianbotkiller
Post by brianbotkiller » Thu Jan 29, 2009 8:39 pm
Hi everyone,
audacity 1.3.7 is crashing the second I try to load it on my intel macbook, os x 10.4.11. Has anyone else seen this? I can't even get into the app, it just crashes, and I'm only running regular built in audio out.
Re: 1.3.7 crashes on load
Post by kozikowski » Fri Jan 30, 2009 2:04 am
Leopard?
brianbotkiller
Post by brianbotkiller » Sat Jan 31, 2009 1:24 am
kozikowski wrote:Leopard?
no, tiger. 10.4.11.
Leland
Developer
Post by Leland » Sat Jan 31, 2009 11:19 am
brianbotkiller wrote:Hi everyone,
Brian,
Have you used a previous version of Audacity before this attempt? If so, can you delete your "~/Library/Application Support/audacity" directory or rename it if you like. Next time Audacity start it will recreate it.
Leland
