Using audacity with Lenovo U535
How do you input audio to Audacity using a Lenovo U530 which has a combo audio input?
Re: Using audacity with Lenovo U535
Ignore it and use a stereo USB Behringer UCA202 for line-level work (like my mixer), or one of the USB Microphone amplifiers.
I have Lenovo U530 too. What "kozikowski" mentions works great.trainman wrote:How do you input audio to Audacity using a Lenovo U530 which has a combo audio input?
