editing
njt
editing
Post by njt » Fri Apr 17, 2015 1:34 pm
I downloaded a tape recording and not having time I saved the recording to edit later as advised on the Audacity web site. I expected to see the sound track when reloading the saved file so that I could edit in the normal way but all I got was a blank. I assume that if I transferred to music to a CD or mp3 player it would do so as a complete unit and not divided into tracks. How can I edit without an audio line?
Re: editing
Post by Gale Andrews » Fri Apr 17, 2015 7:02 pm
njt wrote:I downloaded a tape recording
That wording is not clear. Did you record from a USB tape deck? Or did you record from a cassette deck connected to a USB record player?
Are you using Windows 8, or is this a different computer to your last one? What version of Audacity? Please see the pink panel at the top of the page.
njt wrote:not having time I saved the recording to edit later as advised on the Audacity web site.
Did you Save Project or Export? The two are very different.
njt wrote: I expected to see the sound track when reloading the saved file so that I could edit in the normal way but all I got was a blank.
Did you see an error message? If so, please tell us exactly what the error says.
