How does one delete AUP & DATA files from Audacity.app
Help for Audacity on macOS.
Re: Adjusting audio level of one CD track.
Post by Gale Andrews » Tue Apr 14, 2015 7:09 pm
Old Musician wrote:Just to close this .. I finally plugged in a separate CD player and output the audio signal to the Line-In on my Mac Mini. Then played the track I wanted into Audacity and voila, I was able to adjust the recording level, just like it was coming in from a tape machine.
Good. But for those who have a built-in or external CD drive, dragging in the AIFF file from Finder is the preferred solution.
