Unwanted echo effect on recording
jmcalea
Post by jmcalea » Tue Jan 27, 2009 6:40 pm
Hi
Running version 1.2.6 on Windows XP and when recording from Microphone I get an unwanted echo effect. Anyone any ideas on how to fix?
Re: Unwanted echo effect on recording
Post by kozikowski » Wed Jan 28, 2009 3:10 am
You are probably recording yourself twice. Once when your voice goes into the computer and then once again when it plays back out to your headphones or speakers. Windows will cheerfully record both depending on the settings in the Windows Sound Control Panels.
Windows Control Panel
There's always a latency delay between those two services, so you get an echo effect.
Then there's the Smooth Move of the Week possibility. That's where you're recording from the built-in microphone instead of the performance microphone. That microphone will pick up room echoes.
jmcalea
Post by jmcalea » Thu Feb 05, 2009 6:31 pm
Many thanks Koz.
I will give it a go tomorrow.
