hi there, is there anyway we can export the settings that i've setup in the batch file process as xml file?
if not, i'm putting in a request in for this. thanks
exporting batch files process settings
- Quality Assurance
Re: exporting batch files process settings
There is no import and export from/to XML.
However each Chain has its own text file containing the commands and their settings. For you on Windows 8.1 the files are at Users<your user name>AppDataRoamingAudacityChains.
You can copy the files to that same folder on another computer then Audacity on that other computer should see the Chains when you open Edit Chains.
