GVERB isn't loading the settings that i have saved.
Feedback and Reviews for Audacity 2.x
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
yugioh47
Post by yugioh47 » Fri Apr 03, 2015 11:57 am
hi there, when i do the settings for GVERB that i have save it won't load, you can see by the pictures when i do the batch file process:
batch files:
https://www.dropbox.com/s/64ekx4m61sf7a ... 1.jpg?dl=0
https://www.dropbox.com/s/kswosbql4cymd ... 2.jpg?dl=0
https://www.dropbox.com/s/r64qw5p3jyvmh ... 3.jpg?dl=0
https://www.dropbox.com/s/i81er06vchtcm ... 4.jpg?dl=0
as you can see the settings aren't load in to the batch file process.
can some please fix this?
p.s. all audacity dose in the batch file process is load the default not the setting i've setup.
Re: GVERB isn't loading the settings that i have saved.
Post by steve » Fri Apr 03, 2015 1:45 pm
Thanks for the report yugioh47.
This appears to be a bug affecting all LADSPA effects on all platforms, so I've moved this to the "Feedback" section.
I've added this to the bug tracking system.
What appears to be happening is that the Chain uses the "last used" settings rather than the saved settings.
As a temporary workaround if you are batch processing, manually apply GVerb to a track (any audio track) with the required settings (and then Undo, or delete the track) before running the batch process.
yugioh47
Post by yugioh47 » Sun Apr 05, 2015 2:53 pm
thanks steve :)
