Can't start Audacity
Please state:
YIN
Post by YIN » Tue Mar 31, 2015 12:20 pm
Hi!
I run Debian Unstable on a computer. I just installed Audacity 2.0.6 from a Debian repository, but it won't start. When I try to start it I have this error message:
There is very little free space left on this volume.
But there is plenty of free space. Here is what I get by running df -m:
Filesystem 1M-blocks Used Available Use% Mounted on
/dev/sda2 29401 10547 17339 38% /
udev 10 0 10 0% /dev
tmpfs 686 10 677 2% /run
tmpfs 1715 0 1715 0% /dev/shm
tmpfs 5 1 5 1% /run/lock
tmpfs 1715 0 1715 0% /sys/fs/cgroup
none 100 1 100 1% /var/tmp
none 300 1 300 1% /tmp
none 10 1 10 4% /var/log
tmpfs 343 1 343 1% /run/user/1000
Is my /tmp too small?
I'd appreciate any comment.
Re: Can't start Audacity
Post by steve » Tue Mar 31, 2015 12:32 pm
How much space in your Home directory ?
Is Audacity able to write to /var/tmp ?
YIN
Post by YIN » Tue Mar 31, 2015 3:34 pm
My home directory is in /.
df showed that about 17 GB of / was free.
How do I find out whether Audacity is able to write to /var/tmp?
Post by steve » Tue Mar 31, 2015 3:49 pm
YIN wrote:My home directory is in /.
So is that:
Code: Select all
/home/<your-user-name>
YIN wrote:How do I find out whether Audacity is able to write to /var/tmp?
/var/tmp is the default location for Audacity's temporary folder.
Running Audacity should create a folder:
Code: Select all
/var/tmp/audacity-<your-user-name>
Audacity must be able to create that folder (and write to it).
Right click on /var/tmp and select "Properties" then open the "Permissions" tab. The Permissions will probably be greyed out (because the folder is owned by "root") but should say that "Others" have permission to "Create and delete files".
- if this turns out to be the problem then you can either change the permissions of that folder (do that as root), or manually change the Audacity preferences (~/.audacity-data/audacity.cfg) to specify a different location for the temp folder.
YIN
Post by YIN » Tue Mar 31, 2015 5:40 pm
Thanks steve! I changed ~/.audacity-data/audacity.cfg to specify a different location for the temp folder. Now Audacity can start.
To reduce SSD writes I've put /var/tmp on tmpfs. I've limited on its size to 100 MB. I think this is too small for Audacity and caused the problem.
Twhite
Post by Twhite » Tue Apr 14, 2015 6:06 pm
YIN wrote:none 300 1 300 1% /tmp
The problem is that your /tmp is mounted with no file system. I would change that none to tmpfs..
There is a lot more going on in the way of writes in the /var directory than just the logs.
/run/user/1000 is already mounted as tmpfs if /run is mounted as tmpfs.
Why so many tmpfs mounts?
