Recording audio from a video
jzhang172
Post by jzhang172 » Tue Mar 31, 2015 4:06 am
Hi, I know you can do this with audacity but I never got a satisfactory recording, it's just ok, but I'd like high quality audio. Is there a way to extract audios from videos (I know there's websites where you can do this but you need the video downloaded first) or a good way that people record videos and audios?
Thanks
Re: Recording audio from a video
Post by kozikowski » Tue Mar 31, 2015 4:22 am
If it's streaming download, I think your only chance is Stereo Mix. Recording what's playing on the computer in real time.
http://manual.audacityteam.org/o/man/tu ... puter.html
If you have the shows on DVD, you need a decrypter and then a ripper.
Trebor
Post by Trebor » Tue Mar 31, 2015 4:29 am
jzhang172 wrote:... Is there a way to extract audios from videos ...
You can extract , aka "rip" , the audio from a video using Audacity , but you must install something called "FFmpeg" into Audacity first , see ... http://manual.audacityteam.org/o/man/fa ... the_FFmpeg[/i]_Import.2FExport_Library.3F
The then you just drag-n-drop the video file into Audacity and it will extract the audio from the video.
It takes approx 1/20th of the playback time , i.e. ripping the audio from a 1 hour video-file takes about a three minutes.
Also see "How to get audio from vob file" ... http://forum.audacityteam.org/viewtopic ... 7&p=256561
