What are the other files that gets saved other than .aup?
It is a folder with the same file name as the .aup file except it has _data attached to the end of it.
Re: What are the other files that gets saved other than .aup
AUP is the Audacity Project Manager text file. It knows how to put your show together from the snippets and images inside the _DATA folder of the same name. The AUP and the _DATA folder have to be in the same folder or location to open and they have to have the name given to them on creation.
http://manual.audacityteam.org/o/man/au ... jects.html
