stop recording after an hour?
I keep forgetting to turn it off.
How can you set it up so that it automatically stop recordin
Re: How can you set it up so that it automatically stop reco
Transport > Timer Record
You can also use Transport > Sound Activated Recording to avoid recording continuously with no sound.
