Not manually : I used an experimental plugin Steve made "SpectrumToEqCurve" which derives an equalization-curve from a frequency-analysis ... http://forum.audacityteam.org/viewtopic ... 53#p258053horzy wrote:... thanks for your EQ curve. Could you tell me how did you came up with this? I understand it was not done manually considering amount of points on the curve. Or am I wrong?
Identify and suggest plugins used in this recording?
Re: Identify and suggest plugins used in this recording?
Thanks for the link. I didn't know you can do thatTrebor wrote:Not manually : I used an experimental plugin Steve made "SpectrumToEqCurve" which derives an equalization-curve from a frequency-analysis ... http://forum.audacityteam.org/viewtopic ... 53#p258053
