low pass filter problem
djjarge
Post by djjarge » Sat Mar 21, 2015 1:01 pm
No sound after applying low pass filter to my tracks. Win 7 and also on my powerbook g4 os 10.
Worked fine for a couple of projects i did but stopped working suddenly. Using settings rolloff 48 cutoff 80
version 2.0.6 with Bassboost.ny added to plugins
Re: low pass filter problem
Post by steve » Sat Mar 21, 2015 1:10 pm
djjarge wrote:Using settings rolloff 48 cutoff 80
That will pass frequencies below 80 Hz - very low bass only.
Are you sure that you did not mean to apply a high-pass filter with those settings?
djjarge
Post by djjarge » Sat Mar 21, 2015 1:41 pm
This is what I was up too:
I added 3 copys of my stereo track to audacity. I changed these 3 to mono leaving 3 mono tracks and applied the following settings
Track 1
low pass filter: rolloff 48 cut off 80
amplify: to the setting showing in the plug in
eq: flatten and apply 2 times
bass boost: frequency 60 boost 2
Track 2
high pass filter: rolloff 48 cutoff 80
low pass filter: rolloff 48 cut off 100
Track 3
high pass filter: rolloff 48 cut off 100
ampilify: -5
As i said this worked fine on a few projects. Gave me a nice bass bump on track 1 and some control over the mids and highs on tracks 2 and 3.
But now the low pass filter gives me no sound, although the green level indicators are working.
Thanks Steve
Post by steve » Sat Mar 21, 2015 1:54 pm
I think you will need to give us some audio samples.
See here for how to do that: http://forum.audacityteam.org/viewtopic ... 49&t=72887
djjarge
Post by djjarge » Sat Mar 21, 2015 2:26 pm
here are 2 samples, before and after lowpass filter. you can hear a little sound in media player but nothing in audacity.
I am also adding a copy of my lowpass plugin. I don't if it has become altered in some way. maybe someone can find out for me.
Thanks
before.wav
(260.04 KiB) Downloaded 75 times
after.wav
(260.04 KiB) Downloaded 21 times
lowpass.ny
(2.91 KiB) Downloaded 19 times
Post by steve » Sat Mar 21, 2015 3:34 pm
djjarge wrote:I am also adding a copy of my lowpass plugin. I don't if it has become altered in some way. maybe someone can find out for me.
Wow, that's a really old version, but yes that works OK.
djjarge wrote:here are 2 samples, before and after lowpass filter. you can hear a little sound in media player but nothing in audacity.
Works fine here.
What speakers / headphones / sound card are you using?
Do you have "Wow Effect" or any other effects enabled in media player?
djjarge
Post by djjarge » Sat Mar 21, 2015 5:23 pm
These tracks were made on another laptop. They need more work , but basically this is how they should be when using the above settings.
track 1 and 2 have no sound in audacity on this computer.
HP/Compaq 8510p
SoundMax Integrated Digital HD Audio
However, using an older version of Audacity ( 2.0) on this computer, the low pass filter works .
track1.wav
(451.19 KiB) Downloaded 16 times
track2.wav
(451.19 KiB) Downloaded 18 times
track 3.wav
(451.19 KiB) Downloaded 58 times
Post by steve » Sat Mar 21, 2015 5:28 pm
I can't hear tracks 1 and 2 through my laptop speakers because the frequency range is far too low for the built-in speakers, but they both play fine through my headphones or proper sound system.
DVDdoug
Forum Crew
Post by DVDdoug » Sat Mar 21, 2015 5:36 pm
Same here. (I only tried track 1) There is clearly low-frequency sound. I can see the waveform in Audacity and I can hear it on my headphones.
But, my laptop's tiny built-in speakers can't reproduce bass.
P.S.
You've got a dominate frequency that I calculate/estimate at 72Hz (by counting the cycles over a period of time).
djjarge
Post by djjarge » Sat Mar 21, 2015 5:46 pm
Hooked the hp into the alto tx15 speakers and, volia, all the sound is there.
Thanks guys
