Dear Audacity,
I am using a USB recorder box that has stereo inputs but only one gain control. When I use two microphone inputs how do I adjust each input?. I have no mixer facility but surely there is some adjustment in the Audacity system to individually adjust stereo levels when using the USB input?
regards
Mike Crouch
Adusting Record level when using USB input to Audacity
Mike Crouch
Re: Adusting Record level when using USB input to Audacity
That sounds rather odd. What is the make/model of the device?Mike Crouch wrote:I am using a USB recorder box that has stereo inputs but only one gain control.
Audacity does very little in "real time". Essentially, when recording, Audacity records the audio that it receives without modifying it. Modifying the audio is something that you can do in Audacity after recording.Mike Crouch wrote:I have no mixer facility but surely there is some adjustment in the Audacity system to individually adjust stereo levels when using the USB input?
If you want / need complete control of each audio channel separately, split the stereo track into two tracks using the "Split Stereo Track" option in the track menu (http://manual.audacityteam.org/o/man/tr ... _menu.html).
More information about splitting and joining tracks is here: http://manual.audacityteam.org/o/man/sp ... racks.html
