not showing ant wave forms
Re: not showing ant wave forms
Post by steve » Mon Mar 02, 2015 10:51 pm
OK, it sounds like your connections are not quite right.
Lets go back to what "the job" is.
You wrote:
what i am trying to do is run my dj set up, sing to a karaoke song and record the result.
1) Where does the karaoke backing track come from? Is it an MP3, or one of those special karaoke disks, or a normal CD or ....?
2) Which microphone are you intending to use?
3) Do you have a normal, wired (big XLR plug) hand held mic that you can use while we are getting this all set up right?
gpike19
Post by gpike19 » Mon Mar 02, 2015 11:35 pm
the music is what's known as a "cdg" the music is an mp3 and the words are a seperate file for the graphics. but when it is a "zipped"
file you can play it, move it from folder to folder etc. the mic i'll use for this is a shure sm58. it connected directly to the mixer
via xlr. ready when u are.
Post by steve » Mon Mar 02, 2015 11:55 pm
gpike19 wrote:the music is what's known as a "cdg"
So that's a "karaoke CD" yes?
The way that one would usually record vocals over a backing track with Audacity, is to import the backing track into Audacity (which gives you one track in Audacity with the music), then record the vocals into a second track (while listening to the first track). This is called "overdubbing". The main advantage of this method is that if you mess up part of the vocal, you can make a second "take" (or third, 4th ...) on separate tracks, then edit the takes to get one "perfect" recording.
To do this you need the backing track as a file that you can import (such as a WAV file or an MP3 file).
If you need to play the CDG disk in a karake player (so that the words are displayed, then you would need to take a different approach which is a bit more tricky to get right (because you have to get your vocals right in one take). This second method is:
  • connect the outputs of the karaoke player to the mixer (line inputs on the mixer)
  • connect the mic to the mixer (XLR mic input on the mixer)
  • connect the mixer to the sound card
  • play the CDG disk in your karaoke player, start singing, and record the entire song in one take.
Whichever method you use, you should be listening to the music through headphones and not speakers (the microphone will pick up sound from the speakers and that will spoil the sound quality).
Which approach are you wanting to take?
gpike19
Post by gpike19 » Tue Mar 03, 2015 12:34 am
ok steve, i think we can go with the 1st method because a cdg is actually 2 files, one of which ( the music) is in fact an mp3 file.
i'am sorry but we have another engagement tonight, so if possible i would like to follow up tomorrow. so at your convience please contact me in the morning. approx. 10:00 am central standard time. in the mean time i will find a cdg that is unzipped and
have it available. thank you so very much for your help so far. should i make any changes to my "set up" before we proceed ?
Post by steve » Tue Mar 03, 2015 12:46 am
gpike19 wrote:should i make any changes to my "set up" before we proceed ?
Leave it as it is for now, then we'll do a couple of test runs to get this working a bit at a time. The main problem at the moment is that you have a complicated set-up, so it's difficult to see where the problem(s) is/are.
I'll post back in a bit with instructions for you to try tomorrow.
gpike19
Post by gpike19 » Tue Mar 03, 2015 12:52 am
ok thanks again
Post by steve » Tue Mar 03, 2015 1:17 am
Starting from all of the equipment disconnected from each other.
1) Connect SM58 mic to the left XLR input of the emu.
2) Connect your headphones to the headphone socket of the emu.
3) Connect the emu to the computer with the USB cable.
4) Switch everything on and wait a few moments for Windows to find the emu device.
5) Refer to the emu manual and set a reasonably high microphone level.
6) Open the Windows Sound Control Panel and ensure that Windows can see the emu device, and that the green meter in the control panel responds to you talking into the mic.
The above part must be working first, or Audacity has no chance.
Assuming that the above is all working:
7) Open Audacity (if it's already open, close it down and restart it).
8) In the device toolbar, set the USB device (the emu) as the recording device and as the playback device. Set the number of recording channels to "1 channel (mono)".
9) Press the record button and make a test recording.
What happens?
gpike19
Post by gpike19 » Tue Mar 03, 2015 8:31 pm
hello again steve, well this is the latest. followed your instructions and as far as i can tell both windows and audacity are "seeing"
the mu, as it shows up in widows sound and it shows up in audacity as well. one problem is with connecting the sm 58 to e-mu. no sound if connected to e-mu, but works fine connected to mixer. i did import the mp3 portion of a cdg into audacity and
the waveform is there for the song and plays perfect. but when i try to record it's still a no go, so some progress. if we could just get it to record.
gpike19
Post by gpike19 » Wed Mar 04, 2015 5:06 am
hi steve, well i fooled around and finally got it to record. took some fiddlin around with the settings on e-mu. mostly with
the direct monitoring aspect. the issue with the mic not working in the e-mu had to do with sound levels for the mic. i have a long way to go before i have a sound grasp of editing etc. but it's a start. thanks again for your help. i'm sure i'll be talking
to you again. you could give me a quick class on editing. the wave form is too wide, it touches at both top and bottom. i m gonna get into your manual and see what i can learn. thanks again. owen
Post by steve » Wed Mar 04, 2015 10:36 am
gpike19 wrote:the wave form is too wide, it touches at both top and bottom.
The signal level (hence the height of the waveform) is determined by a number of settings.
When making adjustments to settings, follow the path of the signal (the "signal chain"). In my step-by-step instructions the signal path goes:
Microphone -> XLR lead -> Emu sound card ->(converted to digital) -> USB lead -> Computer (hardware) -> Windows (sound system) -> Audacity -> Hard drive.
Settings for the signal level are available at:
Emu sound card.
Windows sound system (Windows Sound Control Panel)
Audacity, but see below:
The setting in Audacity is the http://manual.audacityteam.org/o/man/mixer_toolbar.html, but this is just a duplicate of the Windows sound system control. It does not work in all cases - it depends on whether the Windows control responds to external commands, which in turn depends on the sound card device drivers. In other words, no need to worry about this control - set the Emu level and then the Windows Sound Control Panel recording level.
On the Emu, adjust the level so that on your loudest sound, all of the green LEDs light up. The yellow LED may just flicker on, but the red LED must not light. If the red LED comes on at all, turn down the level.
Then go to the Windows Sound Control Panel and adjust the recording level. This is often easiest to do if Audacity is open and "monitoring".
To set Audacity so that it monitors the input signal, either click on the recording meter, or select "Start Monitoring" from the recording meter drop-down menu. (little black arrow next to the microphone icon).
Note that the Audacity meters may be resized (see http://manual.audacityteam.org/o/man/me ... l#resizing). Resizing to the full width of your screen makes reading the level much easier. The level that you are aiming for is "maximum peaks up to about -6 dB".
