DSSPro format
mcd
DSSPro format
Post by mcd » Fri Jan 23, 2009 8:50 pm
Will Audacity import files that are created with the DSSPro format? I am interested in importing and editing files created with an Olympus DS 2400 digital voice recorder. I want to edit them to create to create some podcasts.
Thanks!
Re: DSSPro format
Post by kozikowski » Fri Jan 23, 2009 11:33 pm
<<<Olympus DS 2400 digital voice recorder. >>>
As we found in an earlier post, Olympus uses a special 4-bit sound format that won't open up anywhere else in the world--except their own software.
If you're on a Mac, it's a simple cable from Headphone-Out to Mac Line-In. Transfer in real time. If you're on a Windows Deskside, same thing. If you're on a Windows Laptop, that may be a lot harder.
