Record direct (no microphone) Google Translate to Audacity?
jmdraft
Post by jmdraft » Thu Feb 19, 2015 12:50 pm
Windows 7
Audacity Version: 2.0.6
Google Translate (https://translate.google.com/?langpair= ... #en/de/dog) will “speak” audibly, the text entered in it by clicking on the little speaker icon.
I would like to be able to record this for my language lessons. I can do this with Audacity but I have to use the microphone which picks up ambient room noise and makes a “hazy-fuzzy” recording.
Is there a way to do record internally (without the microphone) so that the room noise is not recorded and if so, how?
Re: Record direct (no microphone) Google Translate to Audaci
Post by steve » Thu Feb 19, 2015 2:23 pm
This article in the manual should help:
Tutorial - Recording Computer Playback on Windows
