Eliminate background noise
jmdraft
Post by jmdraft » Tue Feb 17, 2015 5:57 pm
I can record sound coming from my computer e.g. YouTube. However, the recording also picks up hazy, grey, room ambience noise. So, what I would like to know: is there any way to make Audacity do the re cording internally (connect directly to computer) so that it does no pick up the room noise?
DVDdoug
Forum Crew
Re: Eliminate background noise
Post by DVDdoug » Tue Feb 17, 2015 6:04 pm
Yes. Instead of choosing your computer's microphone as your recording device, choose "WASAPI loopback" or "Stereo Mix". See this page.
Depending on your operating system and drivers, your computer may not support WASAPI or Stereo Mix. The above page also lists several other solutions.
