Import WAV problem
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
waxcylinder
Re: Import WAV problem
Post by waxcylinder » Mon Oct 05, 2009 10:15 am
Not reproducible with 1.3.9 on Windows XP-HE-SP3 - the import works fine in the "safer" copy in mode - so this could be a just a MAC problem. Any Unix/Linux users out there who can test this?
BTW in using the workaround "faster" option where the audio clip is just referenced and not actually imported, just be very aware that if you move, delete or rename the original audio clip file then you will get a hole in your project.
Post by steve » Mon Oct 05, 2009 4:38 pm
Seems OK on Linux.
Can we have a bit more detail about the problem.
@ playerx
Exactly what kind of WAV files are they? (16 bit, 24 bit, 44.1kHz, 48kHz....) Are these WAV files that have been exported from Audacity, or from elsewhere?
playerx
Post by playerx » Mon Oct 05, 2009 5:51 pm
stevethefiddle wrote: Can we have a bit more detail about the problem.
My file is exported as signed 16bit WAV(microsoft) audio 44.1kHz using Audacity 1.3.9
I just noticed after importing the Track says 24bit PCM. See attachment.
So I just decided to re-export it again, using the "Other uncompressed files" WAV (Microsoft); Signed 24 bit PCM
This file imports via file menu and drag & drop without a problem.
Screen shot 2009-10-05 at 10.41.15 AM.png (35.38 KiB) Viewed 2486 times
side by side screenshot of the Audacity Project; the broken import; and the successful import;
Screen shot 2009-10-05 at 10.42.24 AM.png (72.12 KiB) Viewed 2487 times
Post by steve » Mon Oct 05, 2009 6:08 pm
Go into Audacity Preferences (Edit > Preferences) and on the Quality tab, change the Default sample format to 16 bit or 32 bit. I suspect that it is on 24 bit and some Macs are known to have problems with 24 bit audio.
playerx
Post by playerx » Mon Oct 05, 2009 6:13 pm
stevethefiddle wrote:Go into Audacity Preferences (Edit > Preferences) and on the Quality tab, change the Default sample format to 16 bit or 32 bit. I suspect that it is on 24 bit and some Macs are known to have problems with 24 bit audio.
Yeap, it was set to 24 bit in the preferences.
Setting it to 32 bit float worked fine and for good measure I tried 16, it worked as well.
bigmouth12349
Post by bigmouth12349 » Thu Oct 21, 2010 11:47 pm
I'm having the same problem! Except your solution doesn't work.
The file is DEFINATLY a wav file, I've checked and checked.
The settings are set to "read directly from the original file,"
but when I import it, all I get is a weird squeaky noise! It's really aggrivating!
Does anyone know what I can do to fix this? I just got audacity, and not being able to work it is driving me insane.
I have Windows XP, and the file is 7.68 MB. I downloaded it off of my ipod using a downloader app, but as I said before, it is DEFINATLY a wav file, when I look in the proporties, it says "WAVE Audio File."
Please help?!
Post by kozikowski » Fri Oct 22, 2010 12:27 am
It's not a regular WAV file. If you can open it in Audacity and it plays super fast, then you have a compressed file type that Audacity doesn't understand how to manage.
Download either LRMonoPhase or Piano2 from here and open them in Audacity.
http://www.kozco.com/tech/soundtests.html
Do they sound OK?
bigmouth12349
Post by bigmouth12349 » Fri Oct 22, 2010 12:42 am
kozikowski wrote:It's not a regular WAV file. If you can open it in Audacity and it plays super fast, then you have a compressed file type that Audacity doesn't understand how to manage.
Do they sound OK?
Yes, they both sound fine.
So, how do I make my file sound like this? Is there a way to uncompress it?
I've tried just opening the file, instead of importing it, and it still plays super fast.
Post by steve » Fri Oct 22, 2010 2:17 am
bigmouth12349 wrote:So, how do I make my file sound like this? Is there a way to uncompress it?
Probably your best bet is the free format converter "SUPER" (by erightsoft).
Downloading SUPER is a link jungle, but worth the effort as it can convert most media formats.
As the file appears to be a WAV file (but obviously isn't), it may take a few goes to get SUPER to convert it correctly, but usually it can handle converting audio files to (normal) WAV format automatically.
bigmouth12349
Post by bigmouth12349 » Fri Oct 22, 2010 2:59 pm
I'll try that, thanks!
I'll post here if I have any more problems (I'm okay with technology, but not super... but you probably figured that out).
