.AU files should be named sequentially (Audacity crashed)
This read-only archive contains discussions from the Adding Feature forum.
New feature request may be posted to the Adding Feature forum.
Technical support is available via the Help forum.
Re: .AU files should be named sequentially (Audacity crashed
Post by Gale Andrews » Fri Feb 20, 2015 2:23 pm
smeezekitty wrote:
Also is your USB drive formatted with FAT32 or NTFS? Usually USB drives are FAT32, but If yours is NTFS and you get the pro version (free trial) of xplorer2 and use View > Raw Contents, it should use the internal NTFS time stamps to time sort the files. The NTFS time stamps are accurate enough to identify which AU file of a stereo pair was written first, so you should avoid the issue of a stereo recording being recovered with left and right channels transposed here and there.
Unfortunately, it is exFat. Does that mean I am out of luck?
The time stamps allow 10mS precious but I don't know if any software can make use of it.
I suspect (but don't know) that is too coarse. NTFS timestamp precision is 100 nanoseconds or 0.0001 milliseconds.
But you could record a brief stereo project to your USB drive and test out whether xplorer2 can timesort the left/right AU files correctly using exFAT. Please let us know.
smeezekitty
Post by smeezekitty » Sat Feb 21, 2015 8:43 am
I have done a few limited tests and so far it seems to get the stereo tracks correct. But I was only testing short files.
Not sure how this is all going to work on 5 gigs of data.
One does have to be careful to sort the files the correct direction.
