Waveform display unchanged after gain or envelope changes
Tapehead
Re: Waveform display unchanged after gain or envelope change
Post by Tapehead » Mon Feb 23, 2015 6:37 pm
Thanks for the info.
No additional changes are anticipated for the 2.1 release (of course after the 2.1 release we will be working on the next release ;))
I'll look forward to a multi-column effects menu then. ;)
http://s64.photobucket.com/user/aaprodu ... 3.jpg.html
Keep only a few sub-menu to group by type etc and 150+ plugins could easily be on view with no
scrolling or submenu access required. I think Gale has already added my vote.
I appreciate the latest attempt to improve the menu but after years of using various browsers I haven't found any comparable solution (I'm a bit of a browser buff).
In my browsers the menu split can be toggled on or off in settings
