Please state:
Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade (see
https://www.audacityteam.org/download/).
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
- Quality Assurance
Post
by Gale Andrews » Wed Apr 15, 2015 5:33 pm
Twhite wrote:Because the inner workings of the Linux operating system are more transparent than Windows it allows you more free and easy access to using kernel technologies like tmpfs to tune your system in a way that is more specific to your use case.
Even Windows does let you use a RAM disk
but the main issue is that Audacity is only a 32-bit application on Windows. We don't turn on the /LARGEADDRESSAWARE flag when compiling Audacity, so even on 64-bit Windows, Audacity can only get 2 GB of RAM allocated to it by the system whereas it could get a theoretical 4 GB if that flag was on (and if the user turns on
4 GT tuning).
