Meta tags
rhkrhk
Meta tags
Post by rhkrhk » Thu Jan 29, 2015 2:32 am
I'm trying to add "composer" to the default metadata screen. I add a line, type in composer, add a value - it works for that particular recording. BUT
I want composer to come up by default.
I can't save the template - either by overwriting tags.xml or saving as composer.xml.
Saving, load composer.xml - nothing -
what am I missing?
thanks
rhk
windows 7/ audacity v. 206
Re: Meta tags
Post by Gale Andrews » Thu Jan 29, 2015 3:05 pm
We don't make a "206" version. If that is not a typo, make sure you have 2.0.6 from http://audacityteam.org/download/windows.
rhkrhk wrote:I'm trying to add "composer" to the default metadata screen. I add a line, type in composer, add a value - it works for that particular recording. BUT
It's a known bug: http://bugzilla.audacityteam.org/show_bug.cgi?id=440 - additional tags are not saved if they have an empty value. Click in the "Value" field for the Composer tag and press SPACE then it will save.
Note that loading a template does not persist after you close the project. If you always want Composer to show, load the saved template that has Composer, then press "Set Default".
