Debug versions are slower than release versions. It's good to use them to debug crashes but it may not be advisable to use them for mission critical recordings.cmac185 wrote:Guess what! The crackling/static/whatever is back in full force!!!!!!! Using Audacity Jan25 Nightly Debug version on Yosemite 10.10.2. It really messed a very important recording and there is nothing I can do about it now. Grrrrr...........
2.1.0 has been released now: http://audacityteam.org/download/mac.
The problem that was fixed was an uninitialised buffer. It won't help if there is some systemic problem causing crackling such as a sub-optimal buffer setting (Audacity > Preferences... then the Recording section) or if some interference is setting up crackling.
I do suggest experimenting with Audio to buffer if you have not yet done so. This can solve some crackling issues, mostly playback issues but sometimes recording issues too. Try taking it below 100 as well as above.
Do recordings made in GarageBand or with some other app have crackle, or only those made in Audacity?
It may be better to do File > Quit Audacity, not File > Close (if that's what you mean).cmac185 wrote:I hadn't done any recordings for a while as I only do it as a backup person. Had to do one again this Sunday and the situation is exactly the same as before. Do one recording and all is fine. Save file then close Audacity to try and keep from having any issues.
What happens if you only launch Audacity when you want to record?cmac185 wrote:Restart Audacity and let sit for probably 45 minutes then start recording.
I am not sure it will help us greatly, but please could you attach a sample: How to post an audio sample.cmac185 wrote:First 15 minutes are fine then gradually the popping sound starts and gets worse until the recording is finished, about 30 minutes. The popping is only heard when other sounds are being recorded. During a speaker's pause, all is quiet including no popping.
The sound at the end reminded me of a machine gun. Very regular sharp pops. On the medium volume passages the pops are visible on the wave form.
The problem that was fixed did not cause crackling to start a long way into a recording, as far as I know.cmac185 wrote:I am using a wireless mic to a receiver and the receiver's output is routed to Line-in on my 2009 MacBook Pro. The midi sample rate is set to the same as Audacity, 44,100. I am recording mono since there is only one channel coming from the mic. Now that I think about it I may have gone to Stereo recording at the end of my last episode several months ago. Hopefully that wouldn't be an issue.
The laptop has other programs minimized, but none that use audio and none are actively running doing anything. Swap file is not being used, lots of extra memory. No Internet connection available.
How long is it since you rebooted the laptop?
Can you monitor the receiver's output in headphones? Is the crackle there?
