We need to be sure whether this is a recording issue or not. I'm not 100% clear it's a recording issue.cmac185 wrote:I've read of others having static on recording, but it goes away when the file is exported. Unfortunately in my case it is still there after exporting and playing it in ITunes. I've exported to .aiff and MP3 with same results. I'm recording in Mono and at a 22050 project rate.
I've tried 2.0.6 and the nightly build of Jan 4th 2015. 2.0.6 was far worse.
On 2.0.6 it starts after about 5-7 minutes of recording speaking and is very much like static, but only occurs when there is speaking. When the recording is silent there is no "static". I can see lots of little spikes when I spread the audio out. Most are only about 6 samples long.
On the nightly build of Jan 4th it was fine for about 50 minutes then started having issues.
If you never played the recording before exporting it, the playback "uninitialised buffer" bug that is fixed in the nightlies after 21st December could occur and you could definitely get crackle exported (even if the recording was perfect).
A good test would be to play before exporting. If you hear crackle in different places each time then as Koz says, that's a playback issue.
Really I would try to test with the nightlies, not just because of the uninitialised buffer playback fix, but because there are some other Yosemite-specific interface and effects fixes. 2.0.6 does not officially support Yosemite.
Another obvious question is your use of 22050 Hz project rate in Audacity. Can you say what your recording device is (make and model number)? If it's any kind of upmarket external device it will not be defaulted to 22050 Hz. It will absolutely be expecting 22050 Hz to be set for it in "Input" and "Output" in /Applications/Utilities/Audio MIDI Setup if your recording software is set to that rate. Mismatched sample rates are a primary cause of recording and playback issues.
Changing Audacity "Audio to buffer "might" help, but reducing the buffer usually only helps if it's really a playback problem.
If this was in 2.0.6 it could be relevant, given this was a playback problem and not a recording problem.cmac185 wrote:I don't know if this is related, but on both occasions I recorded another speaker with no problems at all. Immediately after that recording I saved the recording and selected close from the menu. After that I selected a new session. When I clicked on record to start the next recording Audacity crashed. I then restarted Audacity and did the recording that had the issues. Could the crash have left things in a state that is causing the problem?
It should not be relevant in the current nightlies.
