extract notes to wav
atenzor
Post by atenzor » Wed Jan 07, 2015 5:37 pm
If I have a recording of a single musical instrument in either polyphonic or monophonic format, is there a way for audacity to automatically split the track by notes and then export each to a wav file? or any software that can do this?
thanks
Re: extract notes to wav
Post by steve » Wed Jan 07, 2015 6:23 pm
Sounds like you want a program like Propellerhead Recycle (https://www.propellerheads.se/products/recycle/)
atenzor
Post by atenzor » Wed Jan 07, 2015 7:52 pm
steve wrote:Sounds like you want a program like Propellerhead Recycle (https://www.propellerheads.se/products/recycle/)
Hmm, but does that only work on beats (drums) ?
I have harmonic content like flute melody, or horns, strings, etc and need a software that can analyze, detect changes in notes (notes) and extract them to separate wav.
thanks
Post by kozikowski » Wed Jan 07, 2015 8:00 pm
Not in Audacity. This is too close to the frequent request of "extracting the show from the noise and save it as a separate file." You need a sound analysis program, not a simple audio editor.
RamonFHerrera
Post by RamonFHerrera » Sun Jan 11, 2015 8:22 am
kozikowski wrote:Not in Audacity. This is too close to the frequent request of "extracting the show from the noise and save it as a separate file." You need a sound analysis program, not a simple audio editor.
That seems to be what I am looking for, Koz. Which would be the most powerful Sound Analysis program out there?
I found this, but it is only for music:
http://cnmat.berkeley.edu/link/9943
TIA
-Ramon
