Gale Andrews wrote:So I'm clear, does that also mean per selected track, so with 6 selected tracks there are by default six traces? Or only for stereo pairs and tracks assigned to Left or Right?
One trace per channel.
If you select one stereo track and 2 mono tracks, Plot Spectrum will show
4 traces.
Gale Andrews wrote:An obvious issue is handling of multi-channel files, which import as all mono tracks or first two left and right and the rest mono, according to the importer.
It could be very convenient fro identifying the LFE channel.
Gale Andrews wrote:Could there be a High-Contrast View? Perhaps it would have to number the traces at various points and give the key underneath as to which track each number referred to?
If I can have a wish without having to program it myself
I would have a status bar message (or similar) when the mouse pointer is directly over a trace, indicating the track number, track name, and for multichannel (stereo) tracks - the track channel. For example: "Track 1 - Audio Track - Left channel".
Gale Andrews wrote:Do you have any favourites in your long list of options?
Not yet
I'd start with getting the per-channel plots working, then try out some options as experimental features and gather user feedback.
The ability to compare spectra is a very useful feature, but the current Plot Spectrum is very poor for doing so. Addressing that shortfall would be high on my agenda for improving Plot Spectrum.
