low volume and hum using mic
Re: low volume and hum using mic
The perils of troubleshooting a Tough Dog from several time zones away. I got that phrase from a decades old magazine that described repairing TV sets. Back when we had TV sets.
Do you remember why you wanted the microphone?
Did you get the cable checked at the same store that sold it to you? Did they say anything about special driver software?
"Did you get the cable checked at the same store that sold it to you? Did they say anything about special driver software?"
No, that is a long way off. They said nothing about special drivers or software, just that this was all I needed.
"Did they have the same Windows you have?"
The computer shop had the same Windows. The audio was low on the laptop speaker, but the meter looked okay, and he said it seemed fine to him. The computer did install drivers first.
"What did the instructions say? Did you get software with the cable or a way to download it? Do they suggest there is a new special control panel that allows you to control the microphone volume?"
There was no software, no mention of a control panel. Very scant info with no pictures. Instructions said to wait for Windows to install drivers. I did see a message saying drivers were installed, but I'm wondering if I should do it over because the mic wasn't attached before I plugged it in, though I attached it right away.
What do you want me to do in Control panel to "make it worse"?
"Do you remember why you wanted the microphone?"
Yes. In fact if I get this solved soon, I won't need to make a long trip to the station tomorrow (that is today, Friday) to record my voice for my upcoming show, which will be in a big snow storm, so I'm prerecording. But I need to edit and add music at home, so I'd have a second trip to deliver the CDs before snow starts Saturday night. We may be well snowed in Sunday to Wednesday (Maine)--or not, the forecast keeps changing.
Not necessary. The Windows configuration has only to do with the digital USB portion of the cable, not the analog microphone. I'd be surprised if you could do it a second time. Once Windows drivers are installed they tend to stick.I'm wondering if I should do it over because the mic wasn't attached before I plugged it in, though I attached it right away.
Make your voice even quieter than it already is. This is bubbling up to be a very important point. Every time I bring this up you move sideways instead of directly addressing it. The Windows 7 machine I worked with had a volume control for each of its sound connections and in the case of the microphones or inputs, a little volume meter which would flash in time to my voice (or other sound). You should find that volume control and exercise it; run it up and down and see if it acts as we expect it to. Make your voice lower in volume. We are not "helping" your performance. We are making sure the controls work.What do you want me to do in Control panel to "make it worse"?
I know Win7 had its own version of control panels where nobody could find anything, but it had the ability to revert to the "classic" WinXP control panels. Do you know what you have and/or can you locate the slider volume control associated with your microphone?
You can leave Audacity closed for all these exercises. Audacity gets its sound from Windows. If Windows can't manage the sound, that's the end of the story.
We may need to wait for a Windows elf. I never got the Win7 control panels to reliably do what I wanted.
I moved the record level up and down as I recorded, and the playback responded accordingly. Both he voice and hum rise and fall.
"Every time I bring this up you move sideways instead of directly addressing it."
Sometimes I don't understand what you mean.
Would you expect a preamp to correct the hum?
Is there another way to connect the mic?
I've not been following this topic closely, but as I wrote several pages back (http://forum.audacityteam.org/viewtopic ... 61#p263061) the SM58 should be used with a proper XLR lead into an XLR socket.Xerlome wrote:Would you expect a preamp to correct the hum?
How it works is that the microphone uses all three connectors of the XLR plug. One pin is earthed and is used to shield the signal from electrical interference. The other two (known as "hot" and "cold") are twisted around each other and work as a push/pull arrangement for the microphone signal. This is called a "balanced" system, and it is designed to provide excellent immunity from electrical interference. For it to work properly it must be plugged into a balanced input. The microphone inputs of standard computer sound cards are not balanced, so cannot provide the benefits of balanced connections.
More information about balanced signals here: http://en.wikipedia.org/wiki/Balanced_audio
Steve: I took your previous posts to mean that the Shure is not ideal, but might be okay with a preamp. So I asked a music store to order the one you suggested. They said they'd look into it, but they are slow. In the mean time, others suggested other issues, so I've been following those. As you must see, I know about nothing.
Are you saying the Shure is hopeless because the computer won't handle it, or would the preamp correct the hum? Without the hum, I could amplify the recording in Audacity.
Is there a suitable sound card I could get? Without that, do you think there no way to connect the mic effectively?
" "XLR to USB cables" generally don't provide any amplification so are not suitable for voice recording."
The cable the music store sold me doesn't have the control unit shown in the pictures of the product. I still have not determined whether it is missing or just a different version. I have been unable to find any version online without the control unit. But if I were to get the one with the control, would that provide the amplification I need? Assuming there's a way to remove the hum.
As I've said, I don't expect perfection. The station I'm at is not hi-fi. But the hum and the very low volume won't be acceptable.
You should not get hum from a Shure SM58 when plugged into a balanced XLR input unless there is something very wrong with your house electrics. Shure SM58s have been widely used as stage microphones for decades, and "on stage" is a very hostile environment for microphone signals due to the abundance of high power lighting dimmers.
As someone said earlier on, there is nothing wrong with an SM58, though it may not be an obvious choice for podcast recording. You would probably be able to get a "crisper" sound with more sense of "clarity" and "openness" with a sensitive condenser mic, such as the Rode NT1, but that mic is about double the price of an SM58 and you would still need a mic pre-amp (in fact, a true condenser mic such as the Rode NT1 will not work at all without a proper XLR input capable of providing phantom power. "Dynamic" mics such as the SM58 do not require phantom power). The other advantage of an SM58 is that they are extremely robust and reliable - One of the SM58s in my collection is well over 20 years old and still going strong. http://en.wikipedia.org/wiki/Shure_SM58
I'm out of ideas... I don't know what's going on....
Do you have access to another computer you can try? Since you've tested the mic and you've tested the Hosa, I'm still thinking it's computer configuration problem of some kind...
ALL good analog microphones are low-impedance balanced with XLR connectors. Your SM58 should be fine with the Hosa XLR interface, or with some other USB interface that has XLR mic inputs.
Cheap "computer mics" and older "tape recorder mics" are high-impedance unbalanced. But, the microphone input on a regular soundcard or laptop is worthless for high-quality recording because it does not interface properly with any good stage/studio mic. (And the preamp built into a soundcard or laptop is usually low-quality.)
An analog preamp would not work with the Hosa interface. You'd have to connect the preamp's output to your soundcard's line-input. That might solve the problem, but I have no idea what the root of the problem is.
You can test the line-input on your soundcard by connecting something and recording it (a CD player, DVD player, TV, etc.). If that works, a (working) preamp and (working) microphone should also work. (A small mixer would work too and it's easier to find a small inexpensive mixer than to find an inexpensive stand-alone preamp.)
A USB interface with gain controls would allow you to adjust the levels. A mixer with a USB output would also allow you to adjust the gain. But again, I don't know if that will solve the problems.
This seems like an analog problem. Noise is "always" an analog problem. Low signal is almost always an analog problem. The only place you have analog is the microphone and the input-side of the Hosa. But, you've tested the mic and you've tested the Hosa, so I have no idea what's going on...
Since the hum is bad, it's unlikely that Audacity (or any other software) can remove it without damaging the signal. Noise reduction works best when you have a constant low-level backgroiund noise. (Pros still record in soundproof studios with very good equipment because there are limits to what software can do.)
We don't know where the hum is coming from. If the noise get's amplified along with the signal, it's not going to help. If you can boost the signal before the hum comes-in, you'll get a better signal-to-noise ratio.or would the preamp correct the hum? Without the hum, I could amplify the recording in Audacity.
It appears to be working properly. So that puts us back in the idea that the USB connection in your computer somehow is broken — that it does not support your USB microphone cable.I moved the record level up and down as I recorded, and the playback responded accordingly. Both he voice and hum rise and fall.
Hosa Technology, TrackLink Microphone to USB Interface, XLR3F to USB Type A
(from the beginning of the thread)
There is a microphone preamplifier inside your USB cable. That's how they work. It's Mic-Pre, audio amplifier, digitizer and USB management, all in one cable. That's what's crazy about this. Your hardware list should have worked, and in fact it does appear to work, as long as you don't connect it to your computer.
I attached the specifications of your USB cable. What they claim is impossible. They say this cable may be used either before or after a separate Microphone Preamplifier. Nobody can do that. The microphone signal and the signal after a preamplifier can be as much as 1000 times different in volume. They're not directly compatible with each other like they suggest in the document.
Do you sense us walking in circles? If that's true, how did they get it to work in the store?
Changing the preamplifier may be a good way out. Get one that doesn't promise impossibilities and see what happens. That can be an adventure. Each has advantages and disadvantages. As we go.
- Attachments
- Screen Shot 2015-01-02 at 13.54.48.png (126.44 KiB) Viewed 720 times
- Screen Shot 2015-01-02 at 14.05.22.png (42.33 KiB) Viewed 720 times
