Effect High pass filter with Q
юра00
Check.
Post by юра00 » Sun Dec 28, 2014 6:23 pm
[code]
;nyquist plug-in
;version 1
;type process
;name "High Pass Filter with Q..."
;action "Applying High Pass Filter with Q..."
;info "High Pass Filter with Q by David R. Sky"
;control freq "Cutoff frequency" real "Hz" 50 20 10000
;control q "Filter q (resonance)" real "q" 1.00 0.00 5.00
;; Highpass with Q, works on mono and stereo audio
(if (arrayp s)
(vector (highpass2 (aref s 0) freq q)
(highpass2 (aref s 1) freq q))
(highpass2 s freq q))
[/code]
By the way, why the button "code" doesn't work?
Re: Effect High pass filter with Q
Post by steve » Sun Dec 28, 2014 6:43 pm
юра00 wrote:In my editor it looks:
Your editor is not reading the "new lines".
It is important that new lines are retained in the edited file and that the format remains as "plain text".
I don't use Windows, but when I did, I used "Notpad++" which is a very good (free) plain text editor: http://notepad-plus-plus.org/
юра00
Post by юра00 » Sun Dec 28, 2014 7:14 pm
Thank you very much, the document has been edited successfully, the effect with new values works! Explain, please, how to use the button "code", my attempts failed.
юра00
Post by юра00 » Sun Dec 28, 2014 7:18 pm
Code: Select all
;nyquist plug-in
;version 1
;type process
(if (arrayp s)
Post by steve » Sun Dec 28, 2014 7:50 pm
That's OK. There are now double line breaks instead of none, but that should work OK.
The author, David R Sky, was blind (sadly he died a few years ago). Many of his plugins have double line spacing, but that should do no harm.
To use "Code" tags, ensure that there is one
[code] tag at the start of the code and one [/code] closing tag at the end.
Your recent posts had:
Code: Select all
[code]
[/code] at the start and
Code: Select all
[code]
[/code] at the end (which does not work).
Also, ensure that the "Disable BBCode" below the message composing box is not selected.
юра00
Post by юра00 » Sun Dec 28, 2014 8:11 pm
Code: Select all
юра00
Post by юра00 » Sun Dec 28, 2014 8:20 pm
Thank you! "Disable BB code" - default the tick is situated, after taking it away the button has been set to rights.
