Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
юра00
Post
by юра00 » Sun Dec 28, 2014 12:31 pm
Failed to overinstall defaults (cutoff frequency and q), after attempt to chahge the values error message appears or the effect doesn't work. The view of document:
;nyquist plug-in;version 1;type process;name "High Pass Filter with Q...";action "Applying High Pass Filter with Q...";info "High Pass Filter with Q by David R. Sky";control freq "Cutoff frequency" real "Hz" 1000 20 10000;control q "Filter q (resonance)" real "q" 1.00 0.00 5.00;; Highpass with Q, works on mono and stereo audio(if (arrayp s)(vector (highpass2 (aref s 0) freq q)(highpass2 (aref s 1) freq q))(highpass2 s freq q))
such as for High (or Low) Pass Filter, here it is easy to set new values. Other view of the document:
Code: Select all
;nyquist plug-in
;version 3
;type process
;preview enabled
;categories "http://lv2plug.in/ns/lv2core#LowpassPlugin"
;name "Low Pass Filter..."
;action "Performing Low Pass Filter..."
;author "Dominic Mazzoni"
;copyright "Released under terms of the GNU General Public License version 2"
;; lowpass.ny by Dominic Mazzoni
;; Modified by David R. Sky
;; Updated by Steve Daulton June 2012
;; Released under terms of the GNU General Public License version 2:
;; http://www.gnu.org/licenses/old-licenses/gpl-2.0.html .
;; To enable the Q control, remove one semicolon from the start of lines 18 and 32
;control rolloff "Rolloff (dB per octave)" choice " 6 dB,12 dB,24 dB,36 dB,48 dB" 1
;;control q "Filter quality (Q) for 12 dB rolloff" real "" 0.7071 .1 20
;control frequency "Cutoff frequency (Hz)" real "" 16000 1 20000
(cond
((> frequency (/ *sound-srate* 2))
(format nil
"Cutoff frequency is set at ~a Hz but must not~%~
be greater than ~a Hz (half of the track sample rate)."
frequency
(truncate (/ *sound-srate* 2.0))))
((< frequency 1)
(format nil
"Cutoff frequency is set at ~a Hz~%but must be at least 1 Hz."
frequency))
; ((= rolloff 1)(lowpass2 s frequency (max (min q 20) 0.1)))
(T
(funcall
(nth rolloff '(lp lowpass2 lowpass4 lowpass6 lowpass8))
s frequency)))
Please, correct!
юра00 on Fri Apr 24, 2015 4:45 pm, edited 3 times in total.
Reason: code tags added
- Quality Assurance
Post
by Gale Andrews » Sun Dec 28, 2014 4:30 pm
юра00 wrote:Failed to overinstall defaults (cutoff frequency and q), after attempt to chahge the values error message appears or the effect doesn't work. [...] such as for High (or Low) Pass Filter, here it is easy to set new values.
So does this problem happen with
http://wiki.audacityteam.org/wiki/Nyqui ... ter_with_q but not the High Pass or Low Pass?
I tried running Windows is Russian in today's build on Windows but did not see a problem. Please give an example of Cutoff and q values that cause the problem and give us the Debug output.
Are you inputting Cutoff values above half the sample rate? That gives a specific error in High Pass and Low Pass, but only a generic error in High Pass with Q.
- Site Admin
Post
by steve » Sun Dec 28, 2014 4:53 pm
If you want to enable the Q setting, this is the code that you need:
Code: Select all
;nyquist plug-in
;version 3
;type process
;preview enabled
(cond
(format nil
frequency
((< frequency 1)
(format nil
frequency))
(T
(funcall
s frequency)))
I note that in the code comment, the line that says:
Code: Select all
it should actually say;
Code: Select all
;; To enable the Q control, remove one semicolon from the start of lines 20 and 34
I shall correct that for the next Audacity release.
- Quality Assurance
Post
by Gale Andrews » Sun Dec 28, 2014 5:10 pm
steve wrote:If you want to enable the Q setting, this is the code that you need
Did we decide not to make a note about that in the Manual pages for High Pass and Low Pass? I guess the problem may be explaining what Q does or why you might want to enable it.
- Site Admin
Post
by steve » Sun Dec 28, 2014 5:28 pm
Gale Andrews wrote:Did we decide not to make a note about that in the Manual pages for High Pass and Low Pass? I guess the problem may be explaining what Q does or why you might want to enable it.
I think we decided not to mention it. Normally users will get best results with Q set to
1/2(2^0.5) (0.7071...). In those rare cases where users may want to use other Q settings, they will almost certainly know what "Q" is. We also agreed to retain "High Pass Filter with q" as an optional download (on the wiki).
юра00
Post
by юра00 » Sun Dec 28, 2014 5:53 pm
1. Download additional plugin High pass filter with Q.
2. Try to set new value q: 0.88 instead of default 1., save changes in document.
3. Open audacity, Import file, try to apply the effect, but appears:
Copy from Show log.
21:54:47: Audacity 2.1.0-alpha-Dec 26 2014
21:54:47: Trying to load FFmpeg libraries...
21:54:47: Trying to load FFmpeg libraries from system paths. File name is 'avformat-55.dll'.
21:54:47: Looking up PATH environment variable...
21:54:47: PATH = 'C:Windowssystem32;C:Windows;C:WindowsSystem32Wbem;C:WindowsSystem32WindowsPowerShellv1.0'
21:54:47: Checking that '' is in PATH...
21:54:47: FFmpeg directory is in PATH.
21:54:47: Checking for monolithic avformat from 'avformat-55.dll'.
21:54:47: Error: Failed to load shared library 'avformat-55.dll' (error 126: не найден указанный модуль.)
21:54:47: Loading avutil from ''.
21:54:47: Error: Failed to load shared library '.dll' (error 126: не найден указанный модуль.)
21:54:47: Loading avcodec from ''.
21:54:47: Loading avformat from 'avformat-55.dll'.
21:54:47: Error: Failed to load FFmpeg libraries.
21:54:47: Error: Failed to find compatible FFmpeg libraries.
- пост2.png (120.83 KiB) Viewed 1199 times
юра00
Post
by юра00 » Sun Dec 28, 2014 5:59 pm
Attemt to change.
This problem not with High pass filter or Low pass filter, only for filters with q.
- пост3.png (95.16 KiB) Viewed 1198 times
юра00 on Sun Dec 28, 2014 6:03 pm, edited 1 time in total.
- Site Admin
Post
by steve » Sun Dec 28, 2014 6:01 pm
Is "High Pass Filter with Q..." listed once in the list of effects, or twice?
- Site Admin
Post
by steve » Sun Dec 28, 2014 6:03 pm
юра00 wrote:Attemt to change.
Your editor is messing up the lines.
It should look like this:
Code: Select all
;nyquist plug-in
;version 1
;type process
(if (arrayp s)
юра00
Post
by юра00 » Sun Dec 28, 2014 6:08 pm
In my editor it looks:
;control q "Filter q (resonance)" real "q" 0.88 0.00 5.00
It is listed once in the effects. I ask to correct problem with setting default values for the additional effect "High pass filter with q", not to enable q for usual effect High pass filter.
Gale Andrews on Mon Dec 29, 2014 2:19 pm, edited 7 times in total.
