a reliable cd burner
DVDdoug
Forum Crew
Re: a reliable cd burner
Post by DVDdoug » Sat Dec 27, 2014 9:40 pm
..i was told you need author rights to burn a cd with it..this is imgburn..
No. That's not true. ImgBurn can burn Audio CDs, Data CDs or DVDs, etc. (DVDs do need to be "authored" first, but not audio CDs. And of course you need DVD burner to burn DVDs.)
However, you do need to configure ImgBurn to make an Audio CD. If you simply burn WAV or MP3 files to the disc, they will play on your computer but they won't play on a standard Audio CD player.
benbernie
Post by benbernie » Sun Dec 28, 2014 1:57 am
im just going to use windows cd burner..it seems to be the easiest...thanks
