Spectrum analysis [SOLVED]
юра00
Post by юра00 » Sat Dec 20, 2014 12:23 pm
The graph оf spectrum looks:
Does it exist audacity effect, which allows to remove the horizontal lines from the upper part or middle of the spectrum? What do these lines mean?
Re: Spectrum analysis
Post by steve » Sat Dec 20, 2014 1:21 pm
The spectrum may be viewed by switching the track to the "Spectrogram" or "Spectrogram (log f)" view: http://manual.audacityteam.org/o/man/tr ... tml#spgram
Horizontal lines indicate the presence of a tone or a narrow band of frequencies. If the band is high in the spectrum, that may be audible as a high pitched whistle sound. horizontal lines can be filtered out using the notch filter: http://manual.audacityteam.org/o/man/notch_filter.html
To filter out high frequencies, use the low pass filter: http://manual.audacityteam.org/o/man/lo ... ilter.html
To filter out low frequencies, use the high pass filter: http://manual.audacityteam.org/o/man/hi ... ilter.html
For more complex filtering, see the Equalization effect: http://manual.audacityteam.org/o/man/equalization.html
The next version of Audacity will include additional tools for spectral editing.
юра00
Post by юра00 » Sat Dec 20, 2014 1:56 pm
Thank you!
юра00
Re:How to apply Notch filter effect to the selected frequenc
Post by юра00 » Tue Dec 23, 2014 3:04 pm
After selecting the whisle, whiсh is necessary to remove, and clicking the "Speсtral edit multi tool" appears:
I want to avail myself of the " Speсtral edit multi tool", to remove selected frequency, not to enter its value in "Notch filter".
Post by steve » Tue Dec 23, 2014 3:26 pm
I can't read Russian. What does the error message say?
That is not a released version of Audacity. Which exact version is it?
юра00
Post by юра00 » Tue Dec 23, 2014 5:07 pm
Exact version:
Please, explain, how can I change language to English in this version? Is it necessary to download Audacity 2.0.6 again and choose the language, while installing? I 'll send error message again.
Post by steve » Tue Dec 23, 2014 6:08 pm
юра00 wrote:Please, explain, how can I change language to English in this version?
Please see: http://manual.audacityteam.org/o/man/fa ... l#language
юра00
Post by юра00 » Tue Dec 23, 2014 6:24 pm
Report error. Please, explain!
Post by steve » Tue Dec 23, 2014 6:50 pm
Look in the Audacity plug-ins folder and find the file: SpectralEditMulti.ny
Please attach that file to your reply using the "upload attachments" feature below the message composing box.
юра00
Send
Post by юра00 » Tue Dec 23, 2014 8:11 pm
File from Plug-Ins.
(1.53 KiB) Downloaded 42 times
