Is it possible to have alternating left/right vocal sounds
Feedback and Reviews for Audacity 2.x
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
Tko
Post by Tko » Fri Dec 19, 2014 8:36 pm
from one track?
To explain, say this song for example
https://www.youtube.com/watch?v=N942x7n6ZgA
at 0:50, he uses different effects for each name of his artists. Say I'm doing something like that, but rather than different effects, I want to alternate the vocals, so one name comes from the left side, the next name come from the right side (sound-wise).
Does anybody know how to do that?
So in the song it would go lil chuckee (from the right speaker), gudda gudda (left speaker) t-streets (right speaker), and so on from ONE vocal track
I don't mind if the sounds sort of slide from left to right or vice-versa, doesn't have to exactly one name from one side
If this is too confusing, I can explain a bit more, but it should be fairly straight-forward
THANKS! :D
Re: Is it possible to have alternating left/right vocal soun
Post by steve » Fri Dec 19, 2014 9:23 pm
Try the Channel Mixer effect: http://wiki.audacityteam.org/wiki/Nyqui ... nnel_Mixer
Note that a stereo track is required. If you recording is mono you will need to convert it to stereo first - see: http://manual.audacityteam.org/o/man/sp ... racks.html
Post by kozikowski » Sat Dec 20, 2014 1:17 am
We can't split two artists that are singing at the same time. Those two are married.
