How can I get the Apogee Mic to work with Audacity 2.0.5
pilot pip
Post by pilot pip » Fri Dec 19, 2014 5:19 pm
Hi
I cant get my Apogee USB mic to work with Audacity 2.0.5. Ok, I realise this mic is meant to Apple products but Ive heard others can get it to work on windows (Ive got Windows 7).
Anyone got any ideas ?
DVDdoug
Forum Crew
Re: How can I get the Apogee Mic to work with Audacity 2.0.5
Post by DVDdoug » Fri Dec 19, 2014 9:58 pm
If Windows can "see" the mic, it should work with Audacity. Does it show-up in the Windows Control Panel?
Post by kozikowski » Sat Dec 20, 2014 6:43 am
