LAME Download and Install Problems
bahodgson
Post by bahodgson » Thu Dec 18, 2014 7:20 pm
The LAME download site will not respond. I've downloaded LAME from several other sites but it will not install. I have Audacity 2.0.6 on a Windows 7 64 bit system
DVDdoug
Forum Crew
Re: LAME Download and Install Problems
Post by DVDdoug » Fri Dec 19, 2014 4:28 am
It's working for me. Did you download from http://lame.buanzo.org/#lamewindl?
Normally, you download the EXE version and run to install it, and then Audacity will automatically find it. I've never tried "manually" installing it.
acidtrucker
Post by acidtrucker » Fri Dec 19, 2014 9:29 pm
Usually, you just put it in a folder. Then when you export to mp3, Audacity will ask you for the location of lame_enc.dll. I've never used the exe method so I don't know.
