Maybe I'm missing something, but selecting what I want remaining is way too complicated.
Drag Select my desired clip from something larger. Edit > Select > Invert. Del.
Select > Invert
Robert J. H.
Re: Select > Invert
That's essentially
Edit->Remove Special->Trim Audio
Isn't it?
However, you have also to align the start with zero to emulate the true delete behaviour.
Inverting the selection will certainly become important when multiple selections will be introduced.
Isn't it?
billw58
Re: Select > Invert
Yes, and there's a button for it in the Edit Toolbar.Robert J. H. wrote:That's essentially
Isn't it?
The shortcut is Cmd-T (or Ctrl-T for non-Mac users)
-- Bill
Re: Select > Invert
I bet that showed up in 2.0.6.
billw58
Re: Select > Invert
I see it in 1.3.3.
-- Bill
-- Bill
Re: Select > Invert
Attached.
- Attachments
- Screen Shot 2014-12-14 at 18.15.27.png (69.56 KiB) Viewed 3141 times
billw58
Re: Select > Invert
The Trim Audio menu item has moved around. In 1.3.3 it was at the root level of the Edit menu. In 2.0.5 it was in the "Remove Audio or Labels" sub-menu. In 2.0.6 it is under the "Remove Special" sub-menu. It has always had the shortcut Cmd-T.
But as far as I know the "Trim Audio" button has been in the same place in the Edit Toolbar since at least 1.3.3.
-- Bill
