I am still not really clear why you need to check every call live, as opposed to something like Steve's suggestion to pre-check the system for noise and distortion.
You could certainly use Analyze > Silence Finder... in Audacity to check for silences at the noise level in the recorded files. Silences longer than say a couple of seconds could indicate dropouts or completely silent recordings. I am not sure if Silence Finder can be handled well in scripting. Silence Finder writes labels, so if no labels are produced (which displays a warning), that indicates a positive test result.
How long are the calls? Analyze > Sample Data Export... writes text files containing sample levels but is limited to 1 million audio samples. You could write a script to check the text files for long stretches of audio below a threshold as another way to do a check for dropouts.
How to compare two audio files ?
- Quality Assurance
Re: How to compare two audio files ?
Hi,
I have the same need. have you found a solution ?
I described the approach that I would take in this post: http://forum.audacityteam.org/viewtopic ... 53#p261553ansnum wrote:I have the same need. have you found a solution ?
As there was no further comment from Kris I assume that answer was satisfactory.
Hello ,
I am working on similar scenario. Did find any way to compare audio files?
Your question is too vague to give a precise answer (like asking: "How to compare two things").
With Audacity you can easily compare:
- Length of the audio
- Peak level
- RMS level
- Frequency bandwidth
- Sample rate
- Frequency
- Wave shape
- Harmonic content
