RustyL wrote:If Audacity is set to a project rate of 44100, I found out that my Sound Blaster card actually captures at 48k and internally converts to 44.1. In so doing, the clips have been converted to a value less than Audacity would display with red bars. Changing to 48000 project (capture) fixed my problem.
I've only skimmed this topic, but that sounds like the old EMU10K1 / EMU10K2 chips. They were very popular for mid-range Creative sound cards for many years (I've still got a couple of old AWE 32 cards somewhere). The same chips were used in more expensive EMU sound cards. Internally they run at 48 kHz and include on-board DSP (digital signal processing) which is best avoided if you want to do straight recording / playback (but very useful if your interested in sound synthesis).
The drivers for those cards were something of a let-down, but for anyone with > 80% geek rating there were alternative drivers available from the KxProject (
http://www.kxproject.com/).
As you describe, one common quirk was that they clipped below 0 dB. It was possible to avoid that by carefully tweaking the settings (some of which are hard to find). If I remember correctly, the optimum settings on the AWE 32 was to set all levels at 72 %.
Another quirk of several in that range (including the AWE 32) was that the rear line output was higher fidelity than the front line outputs (the Kx drivers swapped the front and rear outputs so that the "main" outputs were from the rear output socket (so as to take advantage of the better sound quality).
There's a fair bit of technical information on the KxProject website (better to read it than rely on my memory - this is going a long way back in history)
