I have a small section of track 02 (Bass) that is slightly late in timing. Can I remove a tad of time before the late bass and therefore make that little section in time with the pre recorded Track 01?
If so, I presume, that, that removed section must be "added/silence" after, so as the rest (2 Tracks) plays in sync.
In other words. How easiest to remove from a selected track, half a second of "delayed audio" without altering the other recorded track 01?
How is easiest method to “Delete” a greyed in selected section of a track?
Pressing the “Delete” button does nothing.
Chris Floyd
Deleting a small section of Track 02
Chris Floyd
- Quality Assurance
Re: Deleting a small section of Track 02
Have you tried Edit > Cut, click where you want the bass to come in, then Edit > Paste? That should keep track 02 the same length.
Press the yellow Stop button before editing.Chris Floyd wrote:How is easiest method to “Delete” a greyed in selected section of a track?
