Auto labelling - possible?
This read-only archive contains discussions from the Adding Feature forum.
New feature request may be posted to the Adding Feature forum.
Technical support is available via the Help forum.
Re: Auto labelling - possible?
Post by Gale Andrews » Wed Dec 10, 2014 1:49 pm
steve wrote:
Gale Andrews wrote:If a count reset or a label sort needs "years of discussion" then the system is broken IMHO ;) .
"Export to mono MP3: (17 votes)" has been under discussion for nearly 4 years ;)
Which was not helped by the original "votes" not being clear what was wanted by those voters - "set it and forget it so that mono is always encoded at 64 kbps and stereo at 128 kbps".
I don't see count reset and label sort as anything like as complex in terms of what could be wanted.
And I thought we were not far off agreeing what to do about "mono MP3 export" http://forum.audacityteam.org/viewtopic ... 56&t=77424 ? There is the use case above and the usefulness of choosing mono at the same bit rate for increased quality.
I agree with you that "Support for a different output sample rate than input sample rate" should be excluded from that for now (only one person ever asked for it and I think there are other dependent considerations around that). You want to rip out the "stereo/joint stereo" choice but I'm not convinced (given some people insist that "joint stereo" is "impure" or "worse quality" in some sense).
I would say go for it if you can code it - import / export features and bug fixes are woefully neglected. Leave "stereo/joint stereo" in the patch, but argue for it to be removed. Maybe consensus will say it should be removed.
Post by steve » Sun Jan 11, 2015 4:01 am
I agree that some options could be useful, but given that the developer's don't like "preferences bloat", and no-one likes "menu bloat", how would you propose to add options to this feature?
Post by Gale Andrews » Sun Jan 11, 2015 3:20 pm
The Label Track dropdown menu is nowhere near as full as the Audio Track dropdown menu.
Right-click in a label track (outside the label's text box) is unused.
Post by steve » Sun Jan 11, 2015 3:37 pm
Gale Andrews wrote:The Label Track dropdown menu is nowhere near as full as the Audio Track dropdown menu.
The track menus really belong with the track. Normally, options selected in a track menu apply specifically to that track.
Gale Andrews wrote:Right-click in a label track (outside the label's text box) is unused.
It is at the moment, but we've had a number of ideas about right click outside the label's text box. Also there could be multiple label track, which would then be a bit confusing if a right click on one label track has effect on all label tracks.
At the moment I'm leaning toward a second menu item - "Configure Numbered Labels" (or some such), that would open an interface - so "Add Numbered Label" would be a one click, no option command, and "Configure Numbered Labels" would be the GUI.
Gale Andrews wrote:If this gets proposed for 2.1.1, I would still support customisation of the numbered labels (even if they would then be "autolabels" not numbered).
I don't like the name "autolabels". That suggests to me "automatic labelling" (like "Sound Finder" et al.)
How important is the ability to automatically add non-numeric characters? (compared with the usefulness of automatically adding numbered labels)
How about time-stamp labels?
Could be very useful for people using Audacity to record lectures while taking notes.
Post by Gale Andrews » Sun Jan 11, 2015 4:45 pm
Absolutely, what I mean is having an item there to sort labels.
steve wrote:At the moment I'm leaning toward a second menu item - "Configure Numbered Labels" (or some such), that would open an interface - so "Add Numbered Label" would be a one click, no option command, and "Configure Numbered Labels" would be the GUI.
That's fine IMO, if we allow two extra items in the Tracks Menu. Personally I would solve that by having a new Labels menu.
steve wrote:How about time-stamp labels?
Also very useful. But that is not exactly a "numbered" label and then we must have a menu item to configure the automatic text for the labels. Perhaps the command should be "Add Autotext Label"?
